Problem with image rigging?
uncle808us
Post by uncle808us »
Anime Studio Pro Ver.11.2.1
MacBook Pro OSX El Capitan Ver 10.11.6
I am trying to understand how to rig an imported image.
I am getting terrible distortion when manipulating bones connected to the image.
How can this be stopped?
Can it be stopped?
I Thank you.
I use a MacBook Pro, and Anime Studio Pro 11.2
http://uncle808s.blogspot.com
Karl Toon
Re: Problem with image rigging?
Post by Karl Toon »
Have you tried turning down the bone strength on all bones
"If you can dream it, you can do it. Always remember that this whole thing was started with a dream and a mouse." - Walt E. Disney
uncle808us
Mad Dog wrote: ↑Thu Sep 19, 2019 10:32 am Have you tried turning down the bone strength on all bones
First thing I tried. Thanks.
Change bone binding to "Region"?
uncle808us
synthsin75 wrote: ↑Thu Sep 19, 2019 2:34 pm Change bone binding to "Region"?
Thanks @ synthsin75:
This helped a great deal but still has some distortion.
Please remember I am totally new at trying to do this.
I finally realized you had to be on frame one to have the manipulate bone tools working. That was a break thru.
:oops:
With region binding, only the part of the image in the bone strength is influenced. But where bone regions overlap, you can still get some undesired effects. You can correct that by adding child bones just to increase the influence of their parent bone...essentially overpowering the influence of the other overlapping bone region.
uncle808us
Thanks synthsin75.
I'm slowly starting to understand. ( I think.) :wink:
The more bones the more stable it becomes if I understand correctly. Not really sure of the placement.
But I'll keep experimenting.
Is it advisable to turn down the bone influence all the way if I do that it doesn't seem to work when I go to frame 1.The bones move but the image stays still.
I appreciate you help on this and your time.
Thank you.
Yeah, trying to find the right balance can be a bit of trial and error, which is why I usually use point binding. But since you're using images, that would require a smart mesh, which could be more complicated than you may be wanting.
Unless a bone is layer or point bound, turning it's influence to zero means it has no influence at all.
