rigging bones to work with scripted motion
Re: rigging bones to work with scripted motion
EricTheFish wrote: Wed Aug 18, 2021 10:32 am I renamed the pedal axle bone to remove it from script influence and made a new "helper" bone that follows the rotating wheel script instead.
Then I used an angle controller to link the axle bone to the new helper bone and voila! The rig works too! Target bones work as normal.
I must be missing something, because my bones aren't following the target on the bone rotation constrained to the Wheel bone.
Lukas
Post by Lukas »
Lukas wrote: Tue Aug 17, 2021 11:31 pm
synthsin75 wrote: Tue Aug 17, 2021 6:16 pmTo do that using Stan's script, it would have to be modded to write keyframes for the rotating bone.
I’ve made a wheels layerscript that keys the animation (it only keys the necessary frames). I’ll post it here later.
Here's my take on the a script for automatic rotation for wheels, I use it a lot, there's a sample file included. You do need to install the utility file in your scripts folder for it to work:
EricTheFish
Post by EricTheFish »
synthsin75 wrote: Wed Aug 18, 2021 10:48 am I must be missing something, because my bones aren't following the target on the bone rotation constrained to the Wheel bone.
Wes, here's my working test rig file along with Sam's modded version of Stan's wheel script. Just unzip in the same folder and Moho should find the layer script.
There are two bone layers each with Stan's modded layer script:
"Direct" uses the script directly on the pedal hub.
"Bone Helper" uses the script on the helper bone with an angle control link to the pedal hub bone.
Both methods work the same here, the only keyframes are for the root bones X position.
cyclist_rig_test.zip
EricTheFish
www.tech-nique.co.uk
EricTheFish
Lukas wrote: Thu Aug 19, 2021 1:01 am Here's my take on the a script for automatic rotation for wheels, I use it a lot, there's a sample file included. You do need to install the utility file in your scripts folder for it to work:
Great script Lukas, thanks for sharing! :D
EricTheFish
EricTheFish wrote: Thu Aug 19, 2021 3:18 am There are two bone layers each with Stan's modded layer script:
Oh, they're both using the modded layerscript. I thought your workaround was using the original script.
Now I understand.
EricTheFish
Wes, you're right. The helper bone rig doesn't work with the original script as I thought.
My "workaround" is actually irrelevant, I must have not have swapped the scripts properly during my tests or there was come cacheing going on that was interfering. I opened my test file today with the original script and nothing works.
The helper bone idea is therefore irrelevant, you definitely need to use the modded script for this technique. Sorry for the confusion :(
EricTheFish
