DV SELECT PARENT BONE LAYER V 1.8
davoodice2
Post by davoodice2 »
quickly select neatest parent bone. best usage is if you assign a shortcut for it.
go back to bone layer and continue animate quickly.
download https://www.mediafire.com/file/x4iza6i7 ... 8.zip/file
1.7
- change algorithm
- auto collapse
- Auto focus
1.8
- bug fix
Re: DV SELECT PARENT BONE LAYER V 1.0
Brilliant, thank you! will give it a whirl :)
edit:
Works great on direct level - can it look deeper? :idea:
davoodice2
funksmaname wrote: Wed Sep 01, 2021 10:36 pm Brilliant, thank you! will give it a whirl :)
edit:
if you run tool again it goes one level up.
Explain more clearly if I do not understand what you mean
I wondered if it was possible to keep going up a chain until you hit a bone layer, regardless of how deep you already are (a sub folders child layer doesn't go up to the bone) :)
davoodice2
funksmaname wrote: Thu Sep 02, 2021 9:22 pm I wondered if it was possible to keep going up a chain until you hit a bone layer, regardless of how deep you already are (a sub folders child layer doesn't go up to the bone) :)
My main goal in this script was to go back to the main layer with one click when we go to the layers inside the rig and continue the animation or rig without worrying that the wrong layer will be selected.
but we can add a option for search more to find Rig layers outside of top layer.
davoodice2
davoodice2 wrote: Wed Sep 01, 2021 8:36 am quickly select neatest parent bone. best usage is if you assign a shortcut for it.
download https://www.mediafire.com/file/9eisuqtp ... r.zip/file
davoodice2
Update 1.4
davoodice2
I think it work as you told ,now.
Re: DV SELECT PARENT BONE LAYER V 1.8
Thank you! I started using it, I love to go back to the bone layer so easily and being able to press it again to go another level up is great but it automatically collapses the children of the bone layer. I'm not sure if that is intended, I usually prefer to have the layers visible for the same reason that I like this script, to be able to move quicker between layers.
EricTheFish
Post by EricTheFish »
Daxel wrote: Mon Nov 15, 2021 11:46 pm but it automatically collapses the children of the bone layer.
Agreed, I prefer to keep the layer stack open too. I commented out the "Expand" code on lines 46,51 and 86. It works like a dream for me! :)
Great little tool, thanks for sharing davoodice2.
EricTheFish
www.tech-nique.co.uk
ITAK
Post by ITAK »
Thank you, davoodice2! Very, very useful tool!
davoodice2
EricTheFish wrote: Thu Dec 16, 2021 7:15 pm
simple and easy! Enjoy
davoodice2
ITAK wrote: Thu Dec 16, 2021 9:11 pm Thank you, davoodice2! Very, very useful tool!
your welcome. i'm glad to hear this
davoodice2
Daxel wrote: Mon Nov 15, 2021 11:46 pm Thank you! I started using it, I love to go back to the bone layer so easily and being able to press it again to go another level up is great but it automatically collapses the children of the bone layer. I'm not sure if that is intended, I usually prefer to have the layers visible for the same reason that I like this script, to be able to move quicker between layers.
simply comment lines contain expand command with insert -- in line start
davoodice2 wrote: Thu Dec 16, 2021 10:01 pm
Thanks, it worked.
I'm a programmer now 8)
