hi.
until fix this bug you can use this script button.
https://www.mediafire.com/file/sd0g2yad ... h.lua/file
toggle enable disable with each time click
Moho refresh bug
- davoodice2
Moho refresh bug
Re: Moho refresh bug
Doing moho.document:Refresh() every time you switch layers, enter/exit frame zero, etc. might cause a performance lag.
- davoodice2
How can i find time line change? Even i just simple set key on key was exist before?synthsin75 wrote: ↑Sat Nov 13, 2021 11:15 am Doing moho.document:Refresh() every time you switch layers, enter/exit frame zero, etc. might cause a performance lag.
I would at least check that the current layer has been shifted on the sequencer and it's a frame higher than the layer's start frame, so you only run the risk of slowing performance for layers/frames you really need it on.
- davoodice2
Yes you right.synthsin75 wrote: ↑Sat Nov 13, 2021 3:40 pm I would at least check that the current layer has been shifted on the sequencer and it's a frame higher than the layer's start frame, so you only run the risk of slowing performance for layers/frames you really need it on.
For now i add tggle mode with diffrent sound.
