The preview images don't have transparency anymore
So today I noticed that when I render a single image using "previsualizar" (preview?) I get a render without transparency. If I use the export panel and use the export png sequence option like I use to do, the transparency works fine, it's just the render preview that is giving me no transparency. I can see transparency even in the work view.
So what did I mess up? How can I get it back?
SimplSam
Re: The preview images don't have transparency anymore
Post by SimplSam »
If you do Save as PNG from the Preview it should save with transparency. I guess in preview you get an off-white background. Not sure what you expect there instead?
Oh yeah if I save as png on the preview image panel, I get the correct image with transparency. I was clicking on the render cache to get the image from there instead. I'm sleepy today. Thank you.
