Best way to skip or remove a timeline section of project
coinman
Post by coinman »
I just finished an animation episode that is going to have a part 2. In the beginning of the part 2, I need to have the intro for the show, and would like to show one or two highlights from part 1.
When rendering, is there any way to skip a section or sections of a project? As in, go right from timeline 447 to 5328 and not render the in between part?
If not, any way, to delete a chunk of timeline? As in, delete what is in between 447 and 5328?
I fully realize neither of these might be possible. Just looking to show highlights in a new episode without animating the entire sections again! Any suggestions or ideas would be greatly appreciated.
Todd
SimplSam
Re: Best way to skip or remove a timeline section of project
Post by SimplSam »
You can perform 2 seperate exports start-447 and 5328-end, and then recombine them in a Video Editing/Compositing application (or even Moho).
Your best option is to probably start exporting to PNG sequences and then process them in a Video Editing/Compositing application, as the quality of the final output is likely to be better than trying to recombine video files.
coinman
Post by coinman »
Ah, excellent. That sounds like exactly the advice I need. Thank you!!
coinman
Post by coinman »
Thanks again for the great info. This has indeed been just what I needed - I'm just bringing the sequences right back into Moho.
Has also enabled me to create a great teaser trailer with various highlights. }:^)
