If you know a easier way to do this? thank you in advance.
A easier way to reveal all the key frames set in a complex character
i always find shifting key frames very toublesome especually there are a lot of point aniamtion and switch layer key frames set on sub layers of a complex character. I have been using a plugin to review all the layers that have keyframes set but it still very troublesome becasue you have to check each layer in order to show the key frames on the timeline, and you have to un check them to make the key frames disappear.
Re: A easier way to reveal all the key frames set in a complex character
Are you currently using LK_ToggleKeysFilter per chance?
By adding two lines it would show all filtered layers on timeline:
Of course with multiple characters this is not a great solution. I've got the code for that too somewhere, but don't have the time to dig it up atm.
Adding the two lines like this:
layer:SetShownOnTimeline(true)
...Adding the two lines like this:
-- *** ALTERED VERSION ***
-- See: https://www.lostmarble.com/forum/viewtopic.php?t=36921
ScriptName = "LK_ToggleKeysFilter"
LK_ToggleKeysFilter = {}
function LK_ToggleKeysFilter:ColorizeIcon()
return true
end
function LK_ToggleKeysFilter:Name()
return "Toggle 'keys' filter"
end
function LK_ToggleKeysFilter:Version()
return "0.2"
end
function LK_ToggleKeysFilter:IsBeginnerScript()
return true
end
function LK_ToggleKeysFilter:Description()
return "Toggle 'keys' filter in Layer Panel"
end
function LK_ToggleKeysFilter:Creator()
return "Lukas Krepel"
end
function LK_ToggleKeysFilter:UILabel()
end
-- The guts of this script
function LK_ToggleKeysFilter:IsEnabled(moho)
return true
end
function LK_ToggleKeysFilter:IsRelevant(moho)
if MohoMode ~= nil then
if not MohoMode.visibility then
return false
end
end
return true
end
function LK_ToggleKeysFilter:Run(moho)
FO_Utilities:FilterTag(FO_Utilities.keysTag, false, moho)
local layers = FO_Utilities:AllLayers(moho)
if moho:LayersWindowGetSearchContextValue() == FO_Utilities.keysTag then
for i = 1, #layers do
local layer = layers[i]
if FO_Utilities:LayerIsAnimated(moho, layer) then
FO_Utilities:AddTag(FO_Utilities.keysTag, layer, moho)
else
FO_Utilities:RemoveTag(FO_Utilities.keysTag, layer, moho)
layer:SetShownOnTimeline(false)
end
end
else
end
end
endRe: A easier way to reveal all the key frames set in a complex character
Hi Lukas, sorry to dig up this ol' thread but i just wanted to ask, what line of code i would have to add to REMOVE all the Timeline Visibility again when switching the tags offLukas wrote: ↑Fri Mar 29, 2024 1:57 am Are you currently using LK_ToggleKeysFilter per chance?
By adding two lines it would show all filtered layers on timeline:Of course with multiple characters this is not a great solution. I've got the code for that too somewhere, but don't have the time to dig it up atm.Code: Select all
... layer:SetShownOnTimeline(true) ... layer:SetShownOnTimeline(true) ...
Adding the two lines like this:Code: Select all
-- *** ALTERED VERSION *** -- See: https://www.lostmarble.com/forum/viewtopic.php?t=36921 -- *** ALTERED VERSION *** -- ************************************************** -- Provide Moho with the name of this script object -- ************************************************** ScriptName = "LK_ToggleKeysFilter" -- ************************************************** -- General information about this script -- ************************************************** LK_ToggleKeysFilter = {} function LK_ToggleKeysFilter:ColorizeIcon() return true end function LK_ToggleKeysFilter:Name() return "Toggle 'keys' filter" end function LK_ToggleKeysFilter:Version() return "0.2" end function LK_ToggleKeysFilter:IsBeginnerScript() return true end function LK_ToggleKeysFilter:Description() return "Toggle 'keys' filter in Layer Panel" end function LK_ToggleKeysFilter:Creator() return "Lukas Krepel" end function LK_ToggleKeysFilter:UILabel() return "Toggle 'keys' filter in Layer Panel" end -- ************************************************** -- The guts of this script -- ************************************************** function LK_ToggleKeysFilter:IsEnabled(moho) return true end function LK_ToggleKeysFilter:IsRelevant(moho) if MohoMode ~= nil then if not MohoMode.visibility then return false end end return true end function LK_ToggleKeysFilter:Run(moho) FO_Utilities:FilterTag(FO_Utilities.keysTag, false, moho) local layers = FO_Utilities:AllLayers(moho) if moho:LayersWindowGetSearchContextValue() == FO_Utilities.keysTag then for i = 1, #layers do local layer = layers[i] if FO_Utilities:LayerIsAnimated(moho, layer) then FO_Utilities:AddTag(FO_Utilities.keysTag, layer, moho) layer:SetShownOnTimeline(true) else FO_Utilities:RemoveTag(FO_Utilities.keysTag, layer, moho) layer:SetShownOnTimeline(false) end end else for i = 1, #layers do local layer = layers[i] FO_Utilities:RemoveTag(FO_Utilities.keysTag, layer, moho) end end end
Basically with your addition it almost does what i want, it shows the stuff on the timeline automatically but when i press it again it keeps the little checkmarks of all the layers. Just thought i'd ask
- martin_mrt
Hello there,
did you find a solution yet? Im about to do an animation with a lot of point animated parts so im very curious to optimize this workflow.
With this script tool by A. Evseeva, you can do many things, and one of them is to show all animated layers in the timeline.
https://mohoscripts.com/script/ae_keytools
To do that, use the buttons: V v X
V: shows all the animated layers in the timeline.
v: shows only those animated after frame 1
X: don't show any layer in the timeline
Some features of the tool may not work correctly because it is a little bit old, but those 3 buttons work perfectly, I use them all the time.
Yea i have the Keytool. It's nice and all but it requires two clicks instead of one OR instead of one shortcut to show me the stuff
