any way to make animation gif?
I have been tryin for a wile now and i was woderin how u make a moho animation gif. theres alot of options but gif isnt one of them
Gif is not an export option in Moho. You would need to find another tool to do that from the exported Moho animation.
Gif requires some "intelligent" thinking on the part of the application since the color format needs a custom indexed palette and the resulting images are ditthered... or not... depending on what you need specifically. You are better off using a program dedicated to this for best results.
There are probably a ton of free apps out there for animated gif creation. Do a search on the web.
If you have Photoshop... Imageready comes with it. Excellent tool for animated gif.
-Vern
-Vern
great way to make gif
you can make a gif with the program: IrfanView
you make an animation, export it in avi or mov, open it with IrfanView and choose "extract all frames".
then you open any gif animating program and choose "animation wizard", and you select in the wizard all the exported frames from the avi.
and whala you have a gif, you can do anything to it, like transperent gif and more.
and you can export it without looseing your quality.
