Can Someone Explain this to Me?
- Yosemite Sam
I have a simple fire using particles. The problem is, once I move I go past frame zero, it doesn't work. it's like the main group is linked only to the mask at the bottom (which I turned on the path for the mask so it's easier to see. I thought maybe I had KFs before frame 0 but can't spot any. Could someone open this file and let me know if they can locate the issue?
Thanks
I added it twice because I'm still unsure which method works on this site.
https://www.dropbox.com/scl/fi/vqdqdc6b ... d65kn&dl=0
Thanks
Jimmy Mills
Some of my Moho Pro work.
Re: Can Someone Explain this to Me?
Looks like it works fine here, in v14.3.
Will check it out in a bit.
What I prefer to do is replace dl=0 at the end of the link with raw=1. This makes the link download the file immediately, without sending the user to an external DropBox page.
Both links take me to your Dropbox page. Then I can download from your page.Yosemite Sam wrote: ↑Sun Jan 19, 2025 4:45 pm I added it twice because I'm still unsure which method works on this site.
- Yosemite Sam
Thanks for checking, Wes
Jimmy Mills
- Yosemite Sam
Thanks for that Green!Greenlaw wrote: ↑Sun Jan 19, 2025 7:10 pm Will check it out in a bit.
Jimmy Mills
- hayasidist
All fine here 14.3 Win 10.
What exactly is not working for you?
- Yosemite Sam
Jimmy Mills
- Yosemite Sam
Green, this is what I'm seeing on my end.Greenlaw wrote: ↑Sun Jan 19, 2025 7:10 pm Will check it out in a bit.
https://youtu.be/vYcC17J2UaY?si=DklgqUBAKrgJR_XU
Jimmy Mills
- Yosemite Sam
This is what I'm seeing on my end.hayasidist wrote: ↑Mon Jan 20, 2025 2:53 amAll fine here 14.3 Win 10.
Jimmy Mills
That's just a display update issue. If you scrub/play the timeline or render, it is correct.
- hayasidist
yeah - display issue - exactly as Wes says. The work area display isn't updated until you move away from the new key. Do the move as in your video. Then step one frame right and the flame re-appears.
- Yosemite Sam
Yeah you're right. Thanks!synthsin75 wrote: ↑Thu Jan 23, 2025 6:05 pm That's just a display update issue. If you scrub/play the timeline or render, it is correct.
Jimmy Mills
- Yosemite Sam
Thanks!hayasidist wrote: ↑Thu Jan 23, 2025 11:24 pmyeah - display issue - exactly as Wes says. The work area display isn't updated until you move away from the new key. Do the move as in your video. Then step one frame right and the flame re-appears.
Jimmy Mills
