Lost Scripts' Shapes Window (**New** BETA 4 PE 🚀) for Moho 14.3+ Pro
Rai López
Re: Lost Scripts' Shapes Window (**New** BETA 4 PE 🚀) for Moho 14.3+ Pro
Post by Rai López »
And I hope it goes well! Otherwise, there is always the previous one which may be more stable, although I precisely ended up releasing this so soon cause I wasn't experiencing issues, but well, deep changes, you know... So please, everyone take that into account and report any issue. Feedback about performance would be very welcomed too, as my old PC somewhat limits my possibilities to get a real idea. BTW, for anyone with BETA 4 already installed, this time there should be enough with just replacing/overwriting, starting from your CCF, this one file: "\Scripts\Menu\- Lost Scripts\ls_shapes.lua", which should somehow ease switching if necessary... Greetings!
I took a quick look at the update. I haven't had a chance to really use it yet, but I have two comments. Both are mainly cosmetic, but the second one is more important to me...
1. The Info Bar at the bottom is slightly clipped.
I wondered if showing a Swatch would push it down lower, but this had no effect...
I don't have Moho's Large Fonts enabled, but maybe there's a Windows Display setting affecting this. Will poke around with settings when I have time.
2. The icons appear too small on my Surface Laptop Studio computer, so I tried enabling Use Large Buttons, but this has no effect. The GUI is usable on this computer, but it is hard to read. However, the size issue is a general Moho thing...I think all of Moho's button icons are too small on this computer. So, I'm mainly commenting about the Use Large Buttons option not working.
I don't know if these are new issues, so I may switch back to Beta 3 tonight just to compare.
I'm sure the button sizes are fine on my desktop computer with the larger display. Will check that later, too.
Rai López
Post by Rai López »
Thanks for letting me know, Dennis, as due to that I can confirm that's exactly how it looks here if I set Scale and layout for Windows 10 to 125% with a display resolution of 1920 x 1200. I never change Windows scaling due to always had the impression that using 100% is like being in the the safe side, but of course I understand why in some cases it can be necessary, what I mean is that's why I'd never noticed that particular problem, although I've always been aware about the kind of similar display issues when using Moho's Use large fonts setting instead. The problem I've always seen with all this is I'm afraid is not possible (or not an easy task at least, specially for a script using so many tricks) to get the UI showing right in more than one scenario and that's where one have to choose, although I've always tried my best ensuring at least the UI is workable under Use large fonts one... Well, from now on I'll keep an eye on Layout scaling as well to see if something can be done on that regard as well.
Oh, but what I do see here are buttons enlarging as usual if I check Main Menu's Use Large Buttons checkbox and I'm pretty sure they are enlarging for you too, but remember large buttons only make buttons wider for providing extra clickable area and icons remain just the same, so maybe that's why (along with other widgets being bigger) you had the perception they didn't change at all? Plus, there has not been relevant changes that could make a difference on that matter between BETA 3 and 4. Take another look and luckily that will save you some time reinstalling the OLD and SLOOOW... BETA 3 :)
