Curve Point Split Script — Curvature Resets to 0.39 After Splitting
ilvmgct
Post by ilvmgct »
Hi everyone,
I’ve written a Moho menu script that splits a selected point on a curve into two independent endpoints. The script runs correctly: the user selects a point and executes the split from the menu.
Current approach:
Read the selected point’s position and curvature data via M_Curve:GetCurvature, GetWeight, and GetOffset (for both front and back sides);
Use M_Mesh:AddPoint to create a coincident point at the same position;
Use M_Mesh:DeleteEdge to remove the segment between the original point and the new point, breaking the curve;
Attempt to restore curvature data before and after deleting the edge.
The problem:
Regardless of the original curvature value, after splitting, both the original and new points have their curvature reset to 0.39, and the curve visibly changes shape at the split location. I have tried the following without success:
Restoring curvature via M_Curve:SetCurvature / SetWeight / SetOffset before and after DeleteEdge;
Using M_Curve:GetControlHandle / SetControlHandle to manipulate handles directly;
Setting correctBezierHandles = false in M_Mesh:AddPoint;
Setting the last parameter of M_Mesh:DeleteEdge to false;
Directly manipulating the five sub-channels of the “Point Curvature” animation channel;
Changing the order of curvature restoration (before deletion, after deletion, and both).
My question:
Is there a correct way to split a point on a curve while preserving its curvature? Or is this a limitation of the current scripting API? If it is a limitation, is there an officially recommended alternative (e.g., duplicating the layer and deleting points from copies)?
The plugin code is available upon request. Any guidance or suggestions would be greatly appreciated.
Thank you!
https://imgur.la/video/SRI1A9
-- ss_split_point.lua
-- Implements a true break at a point on a curve in Moho, preserving the shape by saving/restoring the full curvature sub-channels.
-- Installation location: User Documents/Moho Pro/scripts/tool/
-- Usage: Select a point with the "Select Points" tool, then activate this tool and click once on the canvas.
ScriptName = "SS_SplitPoint"
SS_SplitPoint = {}
function SS_SplitPoint:Name()
    return "Split Point (Real)"
end
function SS_SplitPoint:Version()
    return "7.0"
end
function SS_SplitPoint:Description()
    return "Break a curve at the selected point, preserving the full curvature sub-channels."
end
function SS_SplitPoint:IsEnabled(moho)
    if (moho.layer:LayerType() ~= MOHO.LT_VECTOR) then return false end
    if (moho:CountSelectedPoints() < 1) then return false end
    return true
end
-- Core logic
function SS_SplitPoint:OnMouseDown(moho, mouseEvent)
    local layer = moho:LayerAsVector(moho.layer)
    if (layer == nil) then return end
    local mesh = layer:Mesh()
    if (mesh == nil) then return end
    local frame = moho.frame
    -- 1. Get the first selected point
    local selPtID = -1
    local selList = MOHO.SelectedPointList(mesh)
    for i, pt in ipairs(selList) do
        selPtID = mesh:ClosestPoint(pt.fPos)
        break
    end
    if (selPtID < 0) then return end
    local selPoint = mesh:Point(selPtID)
    local posA = LM.Vector2:new_local()
    posA:Set(selPoint.fPos.x, selPoint.fPos.y)
    -- 2. Find the curve and segment that this point belongs to
    local targetCurveID, targetSegID = -1, -1
    for curveID = 0, mesh:CountCurves() - 1 do
        local curve = mesh:Curve(curveID)
        if (curve ~= nil) then
            for segID = 0, curve:CountSegments() - 1 do
                local p1 = LM.Vector2:new_local()
                local p2 = LM.Vector2:new_local()
                local p3 = LM.Vector2:new_local()
                local p4 = LM.Vector2:new_local()
                curve:GetControlPoints(segID, p1, p2, p3, p4, false)
                if (self:VecEqual(p1, posA) or self:VecEqual(p4, posA)) then
                    targetCurveID = curveID
                    targetSegID = segID
                    break
                end
            end
        end
        if (targetCurveID >= 0) then break end
    end
    if (targetCurveID < 0 or targetSegID < 0) then
        moho:UpdateUI()
        return
    end
    local curve = mesh:Curve(targetCurveID)
    if (curve == nil) then return end
    -- 3. Check whether this point is a curve endpoint (connected to only one segment)
    if (curve:CountSegments() <= 1) then
        return
    end
    -- 4. * Save the full curvature data of the original point (five sub-channels)
    local curvePtID_A = curve:PointID(selPoint)
    if (curvePtID_A < 0) then
        moho:UpdateUI()
        return
    end
    -- Save the curvature itself
    local savedCurvature = curve:GetCurvature(curvePtID_A, frame)
    -- Save the front side (near point a) weight and offset
    local savedWeightIn  = curve:GetWeight(curvePtID_A, frame, true)
    local savedOffsetIn  = curve:GetOffset(curvePtID_A, frame, true)
    -- Save the back side (near point e) weight and offset
    local savedWeightOut = curve:GetWeight(curvePtID_A, frame, false)
    local savedOffsetOut = curve:GetOffset(curvePtID_A, frame, false)
    -- 5. Add a new point B at the original position, disabling Bezier handle auto-correction
    mesh:AddPoint(posA, selPtID, targetSegID, false, frame, false)
    -- 6. Find the mesh ID of the newly added point B
    local newPtID = -1
    for i = 0, mesh:CountPoints() - 1 do
        local pt = mesh:Point(i)
        if (pt ~= nil and self:VecEqual(pt.fPos, posA) and i ~= selPtID) then
            newPtID = i
            break
        end
    end
    if (newPtID < 0) then
        moho:UpdateUI()
        return
    end
    -- 7. Find the segment between A and B and delete it
    local foundSeg = false
        local c = mesh:Curve(curveID)
        if (c ~= nil) then
            for segID = 0, c:CountSegments() - 1 do
                c:GetControlPoints(segID, p1, p2, p3, p4, false)
                if (self:VecEqual(p1, posA) and self:VecEqual(p4, posA)) then
                    mesh:DeleteEdge(curveID, segID, frame, false)
                    foundSeg = true
                    break
                end
            end
        end
        if (foundSeg) then break end
    end
    -- 8. * After deleting the segment, restore the saved curvature data to the new point B
    local finalCurve = mesh:Curve(targetCurveID)
    if (finalCurve == nil) then
        moho:UpdateUI()
        return
    end
    local newPoint = mesh:Point(newPtID)
    if (newPoint == nil) then
        moho:UpdateUI()
        return
    end
    local curvePtID_B = finalCurve:PointID(newPoint)
    if (curvePtID_B < 0) then
        moho:UpdateUI()
        return
    end
    -- Restore curvature
    finalCurve:SetCurvature(curvePtID_B, savedCurvature, frame)
    -- Restore the front side (near point a) weight and offset
    finalCurve:SetWeight(curvePtID_B, savedWeightIn, frame, true)
    finalCurve:SetOffset(curvePtID_B, savedOffsetIn, frame, true)
    -- Restore the back side (near point e) weight and offset
    finalCurve:SetWeight(curvePtID_B, savedWeightOut, frame, false)
    finalCurve:SetOffset(curvePtID_B, savedOffsetOut, frame, false)
    moho:UpdateUI()
end
-- Helper function: compare two Vector2 values for equality (tolerance 1e-4)
function SS_SplitPoint:VecEqual(a, b)
    if (a == nil or b == nil) then return false end
    local dx = a.x - b.x
    local dy = a.y - b.y
    return (dx * dx + dy * dy) < 1e-8
end
-- Standard tool functions
function SS_SplitPoint:Run(moho) end
function SS_SplitPoint:DoLayout(moho, layout) end
function SS_SplitPoint:OnMouseMove(moho, mouseEvent) end
function SS_SplitPoint:OnMouseUp(moho, mouseEvent) end
function SS_SplitPoint:OnKeyDown(moho, keyEvent) end
function SS_SplitPoint:OnKeyUp(moho, keyEvent) end
function SS_SplitPoint:OnSetCursor(moho, mouseEvent)
    mouseEvent:SetCursor(MOHO.CROSSHAIR)
end
function SS_SplitPoint:OnDelete(moho) end
function SS_SplitPoint:OnScriptError(moho) end
return SS_SplitPoint
Re: Curve Point Split Script — Curvature Resets to 0.39 After Splitting
First a polite note: the SS_ prefix indicates that the author is SimplSam. Could you pick the script prefix that is unique and helps to identify you. It's possible (I haven't tried to investigate) that you have other SS_ scripts and there may be function name clashes. More about this here: https://mohoscripting.com/
Then take a look at the code below. This is the factory tool for splitting a curve into equal segments. Note that the guts of the split logic (commented out here) are now in a library call - but the original code is still there for your reference.
obviously, you'll want to add the inserted point at a different coordinate -- modify the line local v = curve:PointOnSegment(segID, i / (self.splitCount + 1)) before deleting the newly created segment.
Hope that helps.
ScriptName = "LM_SplitCurve"
LM_SplitCurve = {}
LM_SplitCurve.BASE_STR = 2460
function LM_SplitCurve:Name()
	return "Split Curve"
end
function LM_SplitCurve:Version()
	return "6.0"
end
function LM_SplitCurve:Description()
	return MOHO.Localize("/Scripts/Menu/SplitCurve/Description=Splits up selected curve segments by adding extra points.")
end
function LM_SplitCurve:Creator()
	return "Lost Marble LLC"
end
function LM_SplitCurve:UILabel()
	return(MOHO.Localize("/Scripts/Menu/SplitCurve/SplitCurve=Split Curve..."))
end
-- Recurring values
LM_SplitCurve.splitCount = 2
-- Split Curve dialog
local LM_SplitCurveDialog = {}
function LM_SplitCurveDialog:new(moho)
	local d = LM.GUI.SimpleDialog(MOHO.Localize("/Scripts/Menu/SplitCurve/Title=Split Curve"), LM_SplitCurveDialog)
	local l = d:GetLayout()
	d.moho = moho
	l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Menu/SplitCurve/Note1=Insert points into selected curve segments:")), LM.GUI.ALIGN_CENTER)
	l:PushH(LM.GUI.ALIGN_CENTER)
		l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Menu/SplitCurve/PointCount=Point count")))
		d.splitCount = LM.GUI.TextControl(0, "0000", 0, LM.GUI.FIELD_UINT)
		l:AddChild(d.splitCount)
	l:Pop()
	return d
end
function LM_SplitCurveDialog:UpdateWidgets()
	self.splitCount:SetValue(LM_SplitCurve.splitCount)
end
function LM_SplitCurveDialog:OnValidate()
	local b = true
	if (not self:Validate(self.splitCount, 1, 10)) then
		b = false
	end
	return b
end
function LM_SplitCurveDialog:OnOK()
	LM_SplitCurve.splitCount = self.splitCount:IntValue()
end
-- The guts of this script
function LM_SplitCurve:IsEnabled(moho)
		return false
	end
	if (moho.layer:CurrentAction() ~= "") then
		return false -- creating new objects in the middle of an action can lead to unexpected results
	end
	return true
end
function LM_SplitCurve:Run(moho)
	local dlog = LM_SplitCurveDialog:new(moho)
	if (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
		return
	end
	local mesh = moho:Mesh()
		return
	end
	moho.document:PrepUndo(moho.layer)
	moho.document:SetDirty()
	MOHO:SplitSelectedSegments(mesh, self.splitCount, moho.layerFrame)
		local ptCount = curve:CountSegments() * self.splitCount
		local pts = {}
		for segID = curve:CountSegments() - 1, 0, -1 do
			if (curve:IsSegmentSelected(segID)) then
				for i = self.splitCount, 1, -1 do
					table.insert(pts, v)
				end
			end
		end
		local ptID = 1
				for i = 0, self.splitCount - 1 do
					mesh:AddPoint(pts[ptID], curveID, segID, moho.layerFrame)
					ptID = ptID + 1
				end
			end
		end
	end
end
ilvmgct
Post by ilvmgct »
Thanks for the reply. I've already changed the plugin name. My plugin QQ_split_point.lua is mainly designed to split points (knots), not curve segments. You can see a demo in the video linked below.
The main problem I'm running into right now is this: on circular or curved non-right-angle edges, after using the plugin to split a point, the curvature of the point becomes 0.39 instead of preserving the original curvature of that point. Does anyone know what might be causing this?
video https://imgur.la/video/SRXHvF
Hoptoad
Post by Hoptoad »
I don't write scripts, but I use them. :D
Maybe look at the code for the script "Split Segment" at mohoscripts.com, written by Hayasidist. When it adds a point to a curve, the curve isn't wrecked.
Good luck!
Here's a link: https://mohoscripts.com/script/hs_splitsegment
ilvmgct wrote: ↑Thu Sep 17, 2026 8:02 am Thanks for the reply. I've already changed the plugin name. My plugin QQ_split_point.lua is mainly designed to split points (knots), not curve segments. You can see a demo in the video linked below.
To get two points where there once was one you logically have to split the segment to one side of the point you wish to duplicate. Add the new point at the same location (or, if it helps you to visualise, a little away in x and y). Figure out what the segment number of the newly added (zero / very short length) segment is and delete it (which it seems you have done). Then (if necessary) move the newly added point to the original position. Using the example code from LM_Split should give the correct curvatures. Note that you now have two end points, so they will each have 3 active curvature sub channels: smoothness (curvature itself); weight and offset. Weight is a "length" scalar to multiply the base smoothness; offset is in radians and represents the angular displacement from the curve's tangent at the point. So it's unlikely that simply copying the values from the original point will achieve the desired effect.
Whilst not directly useful for your situation, this will help you understand how the active curvature channels are used: https://mohoscripting.com/snippets/moho ... conversion
I also note that you refer to curvature of 0.39. This (pedantically 0.391379) is the curvature for a 4 point circle with unit weight and zero offset. So perhaps check the original curvatures of the point you're splitting as you do mention splitting a circular "edge".
