Manipulate Multiple smart bones at once
Kimmiking
Post by Kimmiking »
I am very new to moho and was wondering if there was a way to (Z) manipulate more than one smart bone at a time (not transform)? I tried making smart bone link hierarchy but it stopped working after a single "link". Maybe a way to quickly rotate two or more smart bones to the same angle at the same speed? Thank you!
gaz_hollis71
Re: Manipulate Multiple smart bones at once
Post by gaz_hollis71 »
right, this smart bone linking lark, I've had the same headache on a character rig I was messing about with last winter - got the hierarchy link working for the first bone then it just gave up the ghost. never did work it out properly to be honest. is there a way to batch select the smart bone dials themselves in the timeline and keyframe them together, rather than faffing about one at a time? proper annoying when you've got say four fingers that all need to curl in sync, dunno if theres a trick to grouping the actual bone widgets or if your stuck doing it manually. anyone found a workaround for this or is it just not finished in moho yet
Have them target other bones. This bypasses the limit on how much smart bone nesting you can do, and you can have multiple targets parented or position constrained to a single bone, to control all with an offset... so they all are not pointing to the exact same bone. You can also have these targets controlled by a regular smart bone, but then you lose the ability to also animate the targeting bones manually, unless you untarget them.
Yeah, targeting the bones with a 'dummy' bone should do the trick.
Explanation: To optimize UI responsiveness, Moho ignores a 'daisy-chained' series of Smart Bones beyond one level. However, one can work around this limitation by targeting a bone to the ignored Smart Bone. This forces the Smart Bone to be 'active' to Moho, even when it's further along the chain. The targeting bone doesn't need to actually do anything, so I set its Strength to 0 and enable Shy to hide it.
FWIW, I've used this trick in TV production for many years and haven't noticed any significant performance hit.
(I think I got that right; it's been a while since I've had to do this. Guess I should revisit some old rigs to be sure, but I'm pretty sure that's how it works.) 🤔
I was doing the opposite... having the last smart bone control a target the ignored smart bone is targeting. Either way only works to get one more nested smart bone control. Your way is cleaner, if just needing to activate the second tier control.
But to manipulate multiple smart bones at once, as per the OP, I think having the smart bones do the targeting is the only way.
Hi Wes,
Ah! I wasn't aware of the second way. Thanks for confirming and clarifying!
The method I described was something I figured out during Boss Baby, maybe 10 years ago. This trick came in handy on numerous occasions.😺
