Onion Skin Problem
DVTVFilm
Onion Skin Problem
Post by DVTVFilm »
I'm working on Tut 5.7-- and I'm not getting the Onion Skin to show me layer1 (when I'm on layer2)
Layer 2 is blank, -- no outline from Layer1
I'm pretty sure I need to be on Layer2 in order to draw --but the outline from Layer1 does not show... (as seen in the tut...)
Pix attached...
What am I doing wrong?
regards
7feet
Post by 7feet »
I'm going to figure that you created layer 2 at frame 3, and that may be the problem. Creating new layers inside Switchlayers at other than frame zero is kind of a special case that's mostly been used for importing frame-by-frame (traditional) type animation. Since your new layer effectively doesn't even exist until frame 3, I think the Onion Skinning is interpreting that as nothing does yet. Maybe a glitch, I don't usually use that technique myself, but a good general rule is, unless you have a very specific reason to do otherwise, create all your new layers at frame zero.
DVTVFilm
Post by DVTVFilm »
I'll give that a try--- though the tut definately is telling me to make the new layer at frame 3 (or is it telling me to keyframe it there?) --a matter of interpretation perhaps... I'll try it your way and see...
thanks
7feet
Post by 7feet »
Sorry, I haven't looked at the tuts for a while now, so it's entirely possible I'm just wrong. Hate when that happens.
DVTVFilm
Post by DVTVFilm »
Still can't get it to work... (or I just don't understand the tut.
Is therea manual (a real one) or a BOOK available (or recommended)?
Patmals
Post by Patmals »
Hi DVTVFilm.
As i havent attempted that tutorial yet, i will try it now and get back to you (i hope)
Patmals
Post by Patmals »
Im wondering,
Did you select the 1st layer on frame 1 (by right clicking on swtich layer and choosing layer one), making an onion skin on that frame (nice little blue box appears on the timeline), then on frame 3, doing the same but selecting layer 2?
When you select a layer by right clicking on the switch layer, it should make a keyframe automatically
sorry my description is crap..i just got home..tired :)
Patmals
Post by Patmals »
um, Are you using Anime Studio Pro or Standard?
Because...i hate to burst your bubble but..
Onion skins doesnt seem to be supported in the cheaper version..
http://www.e-frontier.com/go/animestudio/compare
please look at the timeline features..
7feet
Post by 7feet »
I thought that neither were external scripts, but perhaps thats the problem. Dunno, I would figure that if extra scripts were unavailable, they just were. Not that they would non-transparently deny you access. Curious.
Patmals
Post by Patmals »
hmm..i but the image he posted does show a blue box in the timeline referring that a onionskin has been placed.
i wonder why its not working for DVTV..
7feet
Post by 7feet »
Well, the chop-up 'tween standard and Pro probably took a lot of the time we were waiting for it. Not unlikely theres a bit or 2 left over.
Jimmy
Post by Jimmy »
Hi,
I have done a quick flash tutorial showing how I do the MOHO tutorial 5.7
You can see it here:
http://animationtutor.fortunecity.com/TUT5_7MOHO.htm
Hope it helps.
Jimmy
Patmals
Post by Patmals »
Jimmy wrote:Hi,
Hope it helps.
Jimmy
Nicely made Jimmy!!
I hope that helps alot of the new users!!
Jimmy
Post by Jimmy »
Thanks, Patmals!
And thanks for your info on installing AS. (in another post)
Jimmy
Patmals
Post by Patmals »
Jimmy wrote:Thanks, Patmals!
Jimmy
Your mighty welcome :)
