Announcement: PapagayoMOD v1.3.5 (XSheet, Image export, etc)
Discuss Papagayo issues here
mykyl1966
Post by mykyl1966 »
Thank you.
Simple when you know how.
Cheers
Mike R
wizaerd
Post by wizaerd »
Should I just be using the same workflow and methodologies I would if I were using the regular Papagayo? Same help files as well?
Fazek
Post by Fazek »
Yes you're right, it is not neccessary to set it in the OnMouseUp. But if I uncomment the
			self.scrubFrame = -1
in OnMouseUp (I commented it out before), the drag'n'drop is wrong again. It seems it executes the InsertPhonemeOnCurrentFrame after this command so it gets always self.scrubFrame == -1. Maybe the program executes these two things asynchronously in different systems.
I am talking about the 1.3.5 source version. Of course there could be another solution and I hope you already fixed this.
- - - Fazek
nassosy
PATCHES
Post by nassosy »
I commented the "self.scrubFrame = -1"
(its only use was to expose any errors anyway)
Fixed some bugs in the undo/redo system
Uploaded a patch to v1.3.5.1
(Go to the 1st message of the topic)
please verify if everything is ok under linux.
Thanks
P.S.
These windows/Linux differences are starting to get on my nerves.
Rai López
Re: PATCHES
Post by Rai López »
nassosy wrote:P.S.
Well... I only can say you that you've done/'re doing an INCREDIBLE & FANTASTIC work with this program and that I can't be more grateful! :D Hmmm... I hope this helps a little at least :roll: ...GOOD LUCK and THANK YOU again!
Fazek
Post by Fazek »
A notice for Linux users: the link to the 1.3.5.1 source patch points to the compiled win32 files. I hope nassosy will correct it quickly, but until that, if you want to use this for Linux, you can still use the 1.3.5 source. To fix the drag'n'drop bug, add a # character to the beginning of the line 638 of WaveformView.py in the def OnMouseUp... part ( self.scrubFrame= -1).
PS: THAT WAS REALLY FAST! The link fixed! Thank you!
- - - Fazek
nassosy
Post by nassosy »
Sorry for the mixup.
The link to the 1.3.5.1 source patch is now correct
The drag'n'drop bug is not the only thing fixed in the patch.
Fazek
Post by Fazek »
I made a fix for my window size problem. Maybe I made something illegal and I don't know how it looks like under other plafforms, so please check it. There are two separate problems under wxgtk and I am sure the problem is with wxgtk.
In the __do_layout of LipsyncFrame.py:
1 the vertical size of the whole contents (sizer_2) and
2 the vertical size of the left hand side phoneme list (sizer_2_5).
In some cases if I solve 1. the 2. is still goes out of the bottom of the window. It is strange because sizer2_5 is inside of sizer_2... I made the following solution for both of them:
In the line 481:
sizer_2_5.Add(self.thumbnail_panel, 1, wx.EXPAND, 0)
And in the line 544:
sizer_1.SetSizeHints(self.panel_2)
Sorry I don't know the wx protocol but this works.
- - - Fazek
nassosy
Post by nassosy »
Fazek could you post an image of the pMOD when it starts under GTK?
Fazek
Post by Fazek »
- - - Fazek
Uh...
Not a PC guy... not familar with .rar files...
How exactly do I install this on Windows?
EDIT:
Nevermind. Needed to download a better "extractor".
nassosy
Post by nassosy »
Use winrar.
Get it here:
http://www.rarlab.com/download.htm
There is also a version for linux
Thanks.
I got something called "Extract now". Worked perfectly.
keisern
Great work!
Post by keisern »
I've just tried out the version of papagayoMod, and it seems to work very well. I'm just wondering - is it possible to make papagayo remember the screen layout? We work on dual monitors and like to spread the program over two screens to have a better view and work faster.
It would be great if this layout was saved so we didn't have to set it up each time we start the program.
Halvseint, animated talkshow on NRK
www.nrk.no/halvseint
nassosy
Post by nassosy »
Changes from 1.3.5.1 to 1.3.5.2:
*Remembers the window position and size
go here for the download links:
http://nyian.blogspot.com/
I will post there any advances i make to papagayoMOD
in the foreseeable future.
PS. Sorry for the delay but for some reason i cannot edit the first message in this topic.
