magnet line width
magnet line width
his would be very useful when you are working with shapes which have a lot of points.
just like the magnet tool, but instead of moving points, it could modify the width softer.
i was writing this in feature requests section, but maybe it could be just simple script.
what do you think?
what do you think?
If I understand you correctly, this tool already exists.
http://www.lostmarble.com/forum/viewtop ... ht=inflate
However, it doesn't work anymore for some reason. At some update of Moho it stopped working, at least for me. But I suppose it can be easily fixed.
thanks for the answer.
that's right, this doesn't work. i supposed that it's similar to i was thinking.
i have opened lm_magnet.lua and lm_line_width.lua files in notepad, thinking that maybe i could combine both and make my first script ever.
lamentably, i didn't understand anything...
however, that is the idea, a tool just like magnet, but when you drag left or right -instead move the points- the width change softly between several points.
I fixed it, download the new version here:Hiddicop wrote:If I understand you correctly, this tool already exists.
flate.zip
Install the three files in your scripts/tool folder, and restart AS. If you click on a point, the line width of that point increases by a certain amount (alt key: decreases).
Selgin, I think that original LM Line width do exactly what you want it to do.
http://amanoalzada.iespana.es/line-width.html
Just drag your mouse!!!
Another possibility would be put'em alone into the same folder during a night and see what happens at the next day...selgin wrote:i have opened lm_magnet.lua and lm_line_width.lua files in notepad, thinking that maybe i could combine both and make my first script ever.
You'd want to say... fortunately!selgin wrote:lamentably, i didn't understand anything...
thanks rasheed!
this forum is awesome. one day i send a suggestion, the same day Hiddicop tell me someone thought before about and made a script, the samed day rasheed fix the script...
thanks.
i have tested the script and it's different to i was thinking, but i don't know if someone understood me. it's like magnet tool, when you drag the mouse, its move the points in different velocities (the center points move faster than the peripheral points). what i want is that instead of moving the points, it changes the width.
genete, thank you for your flash, but i know how linewidth works and i don't want to change all the points width at the same velocity (es mi inglés, claro, que está tan re malo).
will be nice my AS with some seemonkeys.
thanks.
Another possibility would be put'em alone into the same folder during a night and see what happens at the next day... Laughing
But...
 THE CROSSBREED WORKED!!!
 ...Uh oh! What a funny can be  play to be God Marble!
 ...Ejem, well, as I said it seems work for now but sure it will need some checks & additions, for now I think I like how you can modify the line width according with the direction of the mouse movement (try to move up & down and a little side to side to see) it's very fluid althought I'm not sure if it's  that someone can expect, we'll see... And well, I know, I know... It's quite simple and anyone could have it done better and faster but well, for sure It've been like a good exercise to start as least
 ...ENJOY IT!
 (From HERE...)
THANKS THANKS THANKS THANKS!
it's the best topic reply ever for this poor (but never humble) boy working at 3:32am...
thanks ramón!
te pasaste!
(me tomé la libertad de subirlo acá, por si las moscas de megaupload)
Magnet width (right click, save as)
thanks ramón!
te pasaste!
Rasheed:
Thanks for fixing the script. However it still doesn't work. Everything seems find when you editing the line width, but the change isn't stored. When you go to another frame, the line width is reverted, as had nothing been changed. Am I perhaps doing something wrong?
Ramon:
Thanks for the script!
When I use it, it works fine, but there is an error that pops up in Lua Console:
...r\Anime Studio Pro\scripts\tool\rl_magneto_linea.lua:216: error in function 'Localize'
argument #1 is 'nil'; 'number' expected.
Ramon:
Well, I removed the error messages, didn't I? You're right in the sense that I doesn't store the result into keys. I've updated the script, but I did add a credit at the bottom for modifying the script Brian did. The idea was good, but the script had some syntactic errors in it.Hiddicop wrote:Rasheed:
Here is the revised version: flate.zip
I will contact Brian to tell him what I did to his script.
I'm wake up again! But nothing new...
									...HI! And about that... the error doesn't happend to me in AS 5.5, I've not tried it in Moho yet but I'll do it later to see; I've been take an eye into the script now but I'm not sure about the problem, it's related with GUI functions but I must study it, plus the structure arround the error message it seems identical to other similar AS tools and, well, maybe that's the problem... The truth is that there is some lines there that I can't understand and, well, if someone more esperimented want to take an eye too meantime I go to work it could be like a good excuse to teach us some good (always welcomed) scripting lesson/s... BYE!Hiddicop wrote: ...r\Anime Studio Pro\scripts\tool\rl_magneto_linea.lua:216: error in function 'Localize'
						hey, does anyone still have the magnet width script available to share?  i tried the links in this thread but they don't work anymore.
									Create cartoon characters and comics in minutes: www.bitstrips.com
