Here's some handy scripts
Update
* Updated Paste Curve To Points Position script
For an example see this thread: http://www.lostmarble.com/forum/viewtopic.php?t=3026
Why cannot Download ?
Re: Why cannot Download ?
No Problem for me... EY, Macton! (HELLOtme2000 wrote:Why cannot Download ?
cc_load_layer_animation.lua:614:attempt to index local ? 'layer' (a nil value)Why cannot Download ?
THANKS
Download all (Updated 17 Jan 06)
Here's a zip file of all the scripts below.
http://crashcore.com/public/moho/script ... cripts.zip
UH yeah well those scripts look really handy , but I can´t get any of them to work! I always get that "a nil value" error!! My characters are set up in vector layers under switch layers under bones layers under group layers! - So is it just that the scripts doesn´t work with too complex characters? Ect. when I use the shift layer script it works on some sublayers and not on other??!! Hmmmm
Kasper
There´s no particular reason why it shouldn´t work. It´s probaby just a bug. If you want to send me an example moho file (that doesn´t work) I can look into it when I get a moment.kasjorg wrote:UH yeah well those scripts look really handy , but I can´t get any of them to work! I always get that "a nil value" error!! My characters are set up in vector layers under switch layers under bones layers under group layers! - So is it just that the scripts doesn´t work with too complex characters? Ect. when I use the shift layer script it works on some sublayers and not on other??!! Hmmmm :(
You send me email directly macton [at] crashcore.com
Open to suggestions
Hi everyone!
I have been quite busy lately working on my real job ;) so I haven´t been able to do much with these scripts.
However, I may have a spare moment or two available and if you´re using these these scripts and have some suggestions for improving them (or fixing them) please post them here!
Mike.
Mike.
Hi all!
Perhaps is a stupid question but, does all those scripts work under moho 5.4 for linux??
I've tried some of them and ones close program, other make nothing and other make nothing and send me a message:
cc_reverse_layer_keyframes.lua:528: attempt to index local 'layer' (a nil value)
Don't know that to do.
Any help?
Thanks
Any help?
Thanks
I have a strange problem! I set up my character using simple bone and vector layers - arms and legs on bone layers under the main bone layer. The shift keyframes script (my favorite
) saved me a lot of time and thanks a lot. But now I´ve redone my character and the arms and legs are now under switchlayers attached to a bone in the main bone layer and now the shift keyframes script doesn´t work anymore! Anyone with the same problem? Is there any way to keep my switch layers and still use this great script?
Kasper
Kasper
Kasper
Do these scripts work in Anime Studio Pro?
These scripts look like real timesavers. I upgraded to Anime Studio Pro, though, and I don't know if these scripts will work. Should they work in Anime Studio Pro?
I thought they were loading with Anime Studio Pro, but I made a mistake and started Moho instead. They don't show up in ASP. I guess that means, "no", but if there's a way [perhaps a global search and replace?], that'd be cool.
Stop me if I shouldn't even be trying these scripts with ASP, please! For now, I'm going to stop trying them.
Thanks,
--moonie
Thanks,
--moonie
Save (& Load) Layer Animation help
Could someone walk me thru using the "Save Layer Animation" & "Load Layer Animation"?
I've selected my animation layer and ran the SLA script. I tried saving as: .anme, .lua and a .txt file?
When I open a new document and run the LLA (selecting the previously saved file) I get nothing.
- funksmaname
It happened what I supposed it would happen....
...crashcore.com server is down.
I have only a copy of the main file. Perhaps other can have a copy of the rest of single scripts.
I'll put into a temporary server.
Someone from e-frontier, Fahim or LM should look to this and ask himself about enable a repository of this kind of useful things....
Download cc_moho_scripts.zip
