Announcement: PapagayoMOD v1.3.5 (XSheet, Image export, etc)
Discuss Papagayo issues here
nassosy
Post by nassosy »
I have set up a blog, if anyone is interested
http://nyian.blogspot.com/
I will post there any advances i make to papagayoMOD
in the foreseeable future.
slice11217
Re: Announcement: PapagayoMOD v1.3.5 (XSheet, Image export,
Post by slice11217 »
nassosy wrote:Based on the source code of Papagayo v1.1
NOTE: The download link is at the bottom of the Oxyshare page.
where it says "Fast and Extreme" in blue,
click that to get to the download page.
There you will have to wait 30 seconds before the actual download link appears at the bottom of the page again.
download it from here:
(win32 binary v1.3.5) :
"http://www.oxyshare.com/get/11294156645 ... apagayoMOD 1.3.5.rar.html"
PATCH from v1.3x to v1.3.5.1 for the win32 binary
replace the 'library.zip' file in the program folder with this:
"http://www.oxyshare.com/get/33279724845 ... y.zip.html"
(source code wxPython):
"http://www.oxyshare.com/get/16599683954 ... apagayoMOD 1.3.5 src.rar.html"
Source code PATCH from v1.3.5 to v1.3.5.1:
"http://www.oxyshare.com/get/27531544345 ... apagayoMOD 1.3.5.1 src patch.rar.html"
For Linux, download the source code archive above and
replace the dll files with the ones on the following archive
(corresponding linux files for the DLLs):
"http://www.oxyshare.com/get/19196785004 ... a/papagayo linux files.zip.html"
What? no Mac version?
nassosy
Post by nassosy »
For this to work on a Mac
install the original Papagayo 1.1 source
and then copy the PapagayoMOD source files on top of that
(so that they overwrite the old ones)
You also need the P ython Imaging Library (PIL) package
from here (if it is not already installed):
http://www.pythonware.com/products/pil/
that should do the trick
the source files for PapagayoMOD are here :
http://www.divshare.com/download/208226-607
BTW it seems that the wxP ython package wasn't installed correctly.
try to uninstall it and re-install it.
P.S. Unfortunately I do not own a Mac to confirm
secundar
Post by secundar »
I'm a new user to papagayo. Could not get 1.2 to work on opensuse 10.2 due to wx not being found even though I'm certain it's installed. Perhaps it's because it's py-thon 2.5.
At any rate, thanks for your mod. I couldn't get the download link to work for the linux files but I was able to get the windows exe to run under wine. Dragging phenomes and words that already exist on the waveform works. Dragging phenomes from the left list to the waveform doesn't. There's a lot of flickering on the screen that goes on. Also, I'm not sure if I am supposed to be able to edit the Xsheet but it would help if I could.
nassosy
Post by nassosy »
No you are not supposed to edit the XSheet
(although one should be able to),
sorry for that but i didn't have time.
As for the Drag-and-drop ,
it is implemented differently under win32 and under linux and it gave me a hard time to get it to work.
(even though in your case it doesn't)
Anyways, since alot of people had problems with the ports
if I find some free time,
I am seriously thinking of re-writing papagayoMOD in Java.
and for those who are impatient,
the only thing I can guarantee you is that it will NOT happen
before september.
that's all for now.
nassosy
Post by nassosy »
A tip:
Use the right mouse button to edit words and erase phonemes.
secundar
Post by secundar »
Thanks very much for the response. I do have 1.2 working on ubuntustudio so that will have to hold me over until September. Respect for your coding abilities as well!
threedguy
Post by threedguy »
There is no file there is there another host beside oxyshare to download this file? OyxShare just doesn't work for me as a download host.
http://www.oxyshare.com/get/112941566450fa15e1f076/papagayoMOD 1.3.5.rar.html
The file won't download no matter if i'm using firefox nor IE.
http://www.oxyshare.com/dld/12710613134 ... apagayoMOD
Ray Harryhausen Maddness In 2D
dpolcino
Papagayo Mod rocks!
Post by dpolcino »
I had a massive computer failure so lost this program and had to dig to find it again. This should totally be a sticky topic. It has some really handy features for large projects. Just my 2 c.
ItsMeBobO
Post by ItsMeBobO »
Sorry to revive this old thread.. I am a noob to this forum looking for help on Papagayo.
I have been using PapagayoMod 1.3.5 for about two years. Wanted to try and tweak a few things in the python source code.
The binaries I have.. but the two links to the source code are no longer good. DivShare and OxyShare dont have it.
Did anyone make a back up of the work nassosy did? This would truly be appreciated if you could find that file.
This program has found some new life to animate mouths in light shows. If anyone is interested I can tell you about it.
rocky53204
Post by rocky53204 »
If the files have a .pyo extension I think I have it.
papagayoMOD_1.3.5.3_win32.rar file at 4.63 meg seems to have all associated files.
light shows?
seren animation
Post by seren animation »
Hi rocky53204,
Is it possible to have this please?
rocky53204
I have been called out of retirement for a special project and am working extended hours. I will do my best to find this for you as soon as time allows.
rocky53204
Fairly large collection of files... about 4.6 meg. Transferred to my dropbox at
https://dl.dropboxusercontent.com/u/653 ... _win32.rar
Good luck!
seren animation
Thank you rocky, will download it tonight :)
