However, when I render, I get this:
What's going on? And how do I correct it?
thank for tip, genete. i have a question that maybe could be answered with some of this tricky tricks. can i make a transparent gradient?Genete wrote:I have learned from heyvern (What a lot of thing I have learned from him!! THANKS!) a trick to use properly the gradient. Make one of the colors transparent or semi transparent. It will show the current color of the shape below. In this way you can apply two times a gradient and can have a background color and two gradients (one in one side on other in the other side - light and shadow for example)
That is a great idea, and will save me a lot of hassle later.Genete wrote:I have learned from heyvern (What a lot of thing I have learned from him!! THANKS!) a trick to use properly the gradient. Make one of the colors transparent or semi transparent. It will show the current color of the shape below. In this way you can apply two times a gradient and can have a background color and two gradients (one in one side on other in the other side - light and shadow for example)
(sorry for the non spanish speakers)selgin wrote:but, come on, you are a Genete. and i'm just a little selgin...
yes, that's almost exactly what happens. but the shape still being absolutely opaque, because the base yellow is in 255.The result should be a blue to orange passing by some sort of green in the middle (I think...). I cannot test it now. Please test it for me (for you Wink).
