hoqboy
Post
by hoqboy »
ive made an animation, but when i play, it stops at frame 72, where its highlighted. help's appreciated
-Rafi, 13
Post
by Víctor Paredes »
go to project settings, and put zero as end frame (save as default if you want). your animation will be unlimited.
fiziwig
Post
by fiziwig »
If you are using standard AS, not PRO, you have a maximum of 3000 frames per file. Set the end frame to any number less than 3000.
Setting the ending frame to 0 in the standard version gives you NO frames of animation.
--gary
Post
by Víctor Paredes »
fiziwig wrote:Setting the ending frame to 0 in the standard version gives you NO frames of animation.
no, the animation will last until the last keyframe you add. if there is no keyframes, the animation will last zero.
fiziwig
Post
by fiziwig »
You're right. I stand corrected.
--gary
hoqboy
Post
by hoqboy »
thanks a ton
-Rafi, 13
