I'm french and I've a problem with the free trial AnimStudio
ATTENTION FRANçAISE !
Post by ATTENTION FRANçAISE ! »
Hello,
I'm sorry for my english, I'm french and it's very difficult speaking technical for me in english and even speak and understand english, but I don't how to solve this problem in another way:
I downloaded the version demo of Anim Studio (free trial) and as opposed to
what I believed it does not seem possible to import images made on
Photoshop: is a this bug? or a reality, in spite of what seemed me to
be announced?
Thanks in advance for your answer.
if my English would not be comprehensible enough (my language is French) I join the translation in French if I would fall on somebody who use French:
j'ai téléchargé la version demo d'Anim Studio et contrairement à ce que je croyais il ne semble pas possible d'importer des images faites sur Photoshop: est ce un bug ? ou une réalité, malgré ce qui me semblait être annoncé ?
AS does not import .PSD files.
It will import JPEG, PNG, GIF.
There is a script for Photoshop CS that will export layers from Photoshop to an AS file.
heyvern wrote:There is a script for Photoshop CS that will export layers from Photoshop to an AS file.
If you do not have the Pro version of Anime Studio, you will not be able to use scripts...malheureusement...
Thanks for your help,
then I known now that I can't have everything ! :) ... being given that I don't have either Photoshop CS ( just Photoshop 7 ), even Anim Studio Pro is useless for me !
DominiqueBray
Post by DominiqueBray »
Salut
Je suis fran?ais moi aussi, donc je vais te r?pondre en fran?ais ce sera plus clair. :wink:
Comme le dis heyvern, AnimeStudio ne sait pas ouvrir les fichiers .psd mais il sait ouvrir les .jpg, .gif, et .png.
Je ne sais pas quel est ton niveau d'utilisation de Photoshop, mais au cas o? tu d?butes la chose ? savoir c'est que les fichiers PSD gardent les diff?rents calques s?par?s de l'image, alors que si tu enregistres en JPEG ou GIF l'image sera applatie en un seul calque. En PNG elle sera applatie aussi mais gardera les infos de transparence.
Moi quand je veux importer plusieurs calques d'un fichier Photoshop dans AnimeStudio, je les enregistre un par un. C'est ennuyeux ? faire si tu as vraiment beaucoup de calques, sinon ?a ne prend que quelques secondes.
________
HEADSHOP
ah! je me sens soulagée là ! super merçi à toi de m'avoir topée ! ... je me disais bien aussi que mon anglais devait être du chinois ;) !
eh bien en ce qui concerne Photoshop, ça va plutôt bien entre lui et moi ... trop bien je dirais, il ne me laisse même pas le temps de parfaire mon anglais ! je suis même tellement hypnotisée que je le soupçonne d'en profiter ;) ! enfin voilà quoi, je suis certainement plus forte en Photoshop qu'en anglais en quelque sorte ! :)
mais ce que tu me dis là m'intéresse, car oui bien sûr je connais les calques, les PSD et les JPEG et tout ça et je me doutais un peu qu'Anim Studio ne pourrait pas importer des PSD (comme le disait Vern) car j'utilise aussi Flash. Mais justement, je cherche un autre logiciel que Flash pour faire des animes car je fais tous mes dessins dans Photoshop et sans aplats (je n'aime même pas les contours précis) et avec Flash c'est trop lourd ce système, donc je me demandais si avec Anim Studio ce serait pas mieux: Tu utilises vraiment Anim Studio ? ou Anime Studio Pro ? d'après ce que j'ai compris il y des différences entre les 2 ... mais forcément tout ça c'est en anglais, donc je ne suis jamais très sûre de ce que j'ai pu saisir !
but that script is not for AS, is for photoshop. so there is no limitation with the non pro version.
DominiqueBray
C'est le Pro que j'utilise, mais je crois que les seules diff?rences avec la version normale sont qu'on peut importer des objets 3D et utiliser des scripts.
Tu veux dessiner des ?l?ments dans Photoshop puis les importer dans Anime Studio pour les animer, c'est ?a ? Ou tu veux dessiner les frames d'animation dans Photoshop et faire la composition vid?o dans Anime Studio ?
je suis m?me tellement hypnotis?e que je le soup?onne d'en profiter ;)
J'ai les m?mes soup?ons sur ma tablette graphique... :D
________
Xanax Rehab Forums
selgin wrote:But that script is not for AS, is for photoshop. so there is no limitation with the non pro version.
Oops!!
@ Dominique
Je veux faire l'anim dans Photoshop, en fait, suivant une première expérience, j'ai fait mes dessins à la main (qui peuvent aussi bien être faits dans Photoshop d'ailleurs), je les ai mis en couleur dans Photoshop et je les ai importés dans Flash. C'est ce que je voudrais pouvoir faire au moins avec Anime Studio. Au début, je voulais profiter de Flash pour lui faire faire les inters ("l'intelligence" de la fénéantise ;) ! ) et puis, ça n'a pas été possible avec ce système, donc j'ai fait le minimum toute seule. Alors, en fait, ça dépend de ce qu'Anim Studio peut faire lui, mais je veux faire au moins les animes clefs dans Photoshop (plus si besoin) puis importer ça dans Anime Studio et composer le tout avec Anime Studio. Je n'ai pas besoin de 3D et quant aux scripts, je n'ai pas trop pensé à ça, je ne sais pas si c'est une erreur de ma part.
Est ce que c'est possible aussi avec Photoshop 7 d'importer dans Anime Studio ? avec Flash c'est possible, mais sur la démo d'Anime Studio je n'ai pas pu le faire, alors soit c'est une version limitée (et très limitée :) ) soit, ça se fait par un autre moyen que je n'ai pas encore utilisé, par exemple l'exportation par Photoshop: je sais qu'on peut exporter des PNG avec la transparence mais niveau poids je ne sais pas comment ça compte, parcque l' image au final à l'air déjà assez lourde, moi j'utilisais des JPEG (plus léger même que le GIF).
DominiqueBray
Ah ok, tu fais de l'anim traditionelle et tu cherches un logiciel qui fasse les intervales entre tes frames cl?es.
Non, Anime Studio ne pourra pas faire les intervalles tout seul entre des frames cl?es dessin?es et import?es, il ne sait le faire qu'avec des frames cl?es de dessin vectoriel. C'est la m?me chose pour Flash, ToonBoom, the Tab, etc. , ce sont avant tout des logiciels d'animation vectorielle, ils peuvent importer des images mais ils ne feront les intervales tout seuls qu'avec du vectoriel.
Malheureusement je ne connais pas de logiciel qui sait faire ?a, pourtant ?a doit probablement exister. Regardes "Pencil" et "PAP", ils sont peut-etre plus appropri?s, mais je ne suis pas s?r qu'il fasse les intervalles :
http://www.les-stooges.org/pascal/penci ... hp?id=Home
http://www.plasticanimationpaper.dk/
Comme tu n'aimes pas le look trop parfait du vectoriel, j'imagine qu'il est hors de question pour toi de perdre en plus du temps ? vectorialiser tes dessins. Sinon, Anime Studio est capable de sortir des contours moins parfait, par exemple :
Anime Studio ne peut pas ouvrir directement un fichier .psd, mais le script dont parle heyvern permet ? Photoshop d'exporter un fichier que Anime Studio pourra ouvrir et dans lequel se trouveront tous tes calques de Photoshop. Mais il me semble qu'il faut avoir CS minimum pour l'utiliser. (Moi je n'ai que le 7 comme toi.)
niveau poids je ne sais pas comment ?a compte, parcque l' image au final ? l'air d?j? assez lourde
Pour que tes PNG soient moins lourds, t?l?charge ce plugin : http://www.fnordware.com/superpng/ et met le dans le dossier "Program Files\Adobe Photoshop 7.0\Modules externes\Adobe Photoshop Only\Formats de fichiers". Et quand tu voudras enregistrer en PNG, choisi "Super PNG" au lieu de "PNG".
Bien sur, si tu n'as pas besoin de transparence, utilises du jpg.
________
BMW V12 LMR
Je te remercie pour toutes tes infos,
oui c'est ça, en quelque sorte je veux faire du traditionnel par ordinateur :) mais je ne cherche pas spécialement un logiciel qui fasse les inters, si ça avait été possible oui, mais sinon c'est pas de première importance pour moi. Le problème pour moi avec ma méthode sur Flash, c'est le poids, c'est trop lourd au final (même avec l'anime en JPEG), c'est ça qui m'embête en fait, c'est pour ça que je cherche un logiciel avec lequel je puisse faire les mêmes animes mais qui ne soient pas aussi lourdes ... mais peut-être que je rêve :) peut-être que ça ne se fait pas ?
Je ne cherche pas non plus à importer des PSD, ce n'est pas ce que je voulais dire quand je parlais de Photoshop, j'importe des JPEG avec et je n'ai rien trouvé de mieux malgré le poids final (je pense que j'avais pas saisi le truc parceque c'était en anglais). Alors apparemment, ce serait quand même possible de le faire avec Anime Studio et Photoshop 7, ce serait donc la démo d'Anim Studio qui est très limitée. En tous cas pour ce qui est des contours ça m'a l'air de le faire.
Veuillez excuser la traduction. Quand vous dites : "c'est le poids, c'est trop lourd au final", ce moyen à vous le "volume du dossier" la taille en kilo-octets? La réduction de la taille de Flash est très dure. Le studio d'Anime n'aidera pas. Vous devez étudier Flash pour apprendre ceci.
Merçi beaucoup Vern, c'est très aimable à toi,
Oui, en fait avec ma technique, comme c'est très lourd, c'est aussi très lourd à lire et je ne peux pas dépasser un certain temps d'animation à cause de cela.
Donc, si j'ai bien compris ce que tu m'as dit : le problème est identique avec Flash et Anime Studio alors.
Merçi much Vern, it is very pleasant with you,
Yes, makes some with my technique, as it is very heavy, it is
also very heavy with reading and I cannot exceed a certain time of
animation because of that.
Therefore, if I understood well what you said to me: the
problem is identical with flash and Animates Studio then.
DominiqueBray
Quand tu dis que c'est tr?s lourd, tu parles du poids du fichier .swf ? Si c'est ?a, pourquoi tu n'exportes pas l'animation finale en vid?o .avi compress?e en divx ou xvid ? Ce sera beaucoup moins lourd.
________
NO2 VAPORIZER REVIEW
