Hi,
I'm a new user of Moho and am tearing my hair out trying to figure how to remove the shaky handycam script from my animation.
I'm guessing that it's a case of simply resetting the random camera swings on the camera's animation channel, but am hitting a blank each time I try and clear the effect. It doesn't seem to want to budge. I can't see any keyframes on the camera channels that show the movement.
Short of recreating the scene and popping the steady objects back in it, is there a quicker way?
Apologies if a glaringly obvious solution is in the help file, but I couldn't find any reference to removing applied scripts.
Thanks in advance.
Handycam effect removal
Me, too.
I had the same problem and could not figure out how to delete or stop the shaky camera either.
Or how one could change the amount of camera shaking.
With the orbit camera script one can see in the time line the keyframes and delete and adjust as needed.
But with the shaky camera script I had to start all over with a new file.
Thanks for the tip
Thanks for the tip
Have you figured out how to adjust the shakiness of the camera? Make it more or less shaky?
Ah... of course
Cheers jahnocli, you're a gentleman and scholar. Knew there must be a way to do it. Right hand clicks are an alien thing for the Mac user!
Thanks again for the swift reply.
- Lost Marble
Dear LM, is this question in the FAQ? If not, I suggest putting it there. The shaky cam off-switch question appears regularly. Or put it in a new version of the manual sometime.
Reindert.
www.nobudgetvideo.com
Reindert.
