PLEASE HELP ! HOW I CREAT A...
Please help me. i made an animation and i cant save it. it's save it an a Moho file and i want it on a Jpg or Mov file... someone can help me?
Sounds like you need to export the finished animation by going to File > Export Animation. Then it will let you choose a file you want.
Hope this helps
CrAzY Dan
p.s i think this post needs to go in the 'How Do I...' forum
Hope this helps
CrAzY Dan
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
thanks...
its work. but when i want to make a JPG file Its make a 35 pics and not an animation. help... ?
LittleFenris
Re: thanks...
You can't make a movie file using the JPG option unless you import them into a video editor or compisiting program to put the JPGs together as an animation. The only options you have in Moho to export an animation are AVI (windows movie), MOV (mac quicktime movie) or SWF (Flash movie).Gpoint wrote:its work. but when i want to make a JPG file Its make a 35 pics and not an animation. help... ?
The simplest way to save a still of the current frame is to render that frame using the File>Render command, or hit <CTRL> <F>. When the render window pops up, you'll see a tab that says "Save As...". Click that and you can save the frame in any of the still image formats that Moho supports.
--Brian
--Brian
LittleFenris
From what I can tell they tried saving their Moho animation as a JPG (they mentioned 35 pics) which, of course, you can't do. Not sure why they thought a JPG could be an animation, but they did. The only image format that will animate is a GIF, but even with that I think you need a program that will make animated GIFs (just like you would to make JPGs or any other image into an video format).7feet wrote:The simplest way to save a still of the current frame is to render that frame using the File>Render command, or hit <CTRL> <F>. When the render window pops up, you'll see a tab that says "Save As...". Click that and you can save the frame in any of the still image formats that Moho supports.
--Brian
Start by reading Help file, Reference section, Export Formats.
To be honest, my first thought was "RTFM". But upon glossing over the manual I noticed exporting animations actually isn't really explained very much. Maybe I missed it but you would expect it somewhere in the animation sections...
Reindert.
www.nobudgetvideo.com
Reindert.
LittleFenris
13YearsOldAnimator
I think...
NVM...
Last edited by 13YearsOldAnimator on Fri May 27, 2005 1:16 am, edited 1 time in total.
Heh.. I'm 15 naw! =D
Not completely true, there is an animated version of PNG as well, MNG or JNG, see:LittleFenris wrote:The only image format that will animate is a GIF
http://www.libpng.org/pub/png/png-sitemap.html#animation
The only problem is that neither MNG nor JNG are widely supported. None of my browsers does, so I had to use a seperate MNG viewer to view the animations I created with The Gimp.
