Antializing
DK
Antializing
Post by DK »
Is there a way of turning off or controlling antializing in AS
EDIT: It's ok,...found it in export animation settings...
I wonder why AS does not display an unantialized image in the render display panel when it's turned off????
Is this a bug?
Cheers
D.K
Isn't the F5 preview unantialiased?
DK
Post by DK »
Wow!!! I never knew about the f5 preview!!! Thanks....
The preview I was referring to is is ctrl/r. There is antializing on it when it is set to off on the animation export options.
The f5 preview is a bit small to tell if theres antializing there or not. Funny I never knew about the f5 one....AS is so quick to render it never occurred to me that there should be a movie preview function.
D.K
The F5 preview is done at half dimensions, so if you double your usual output dimensions, you'll get a bigger preview.
:wink:
The ctrl+R render does not use the settings from the export animation thingy. I think it just defaults to the "standard" settings.
I think it SHOULD use the export settings though. That would be very nice.
DK
Post by DK »
Actually the f5 preview is antialized even if the animation settings are set to none. I just made a double size preview to confirm.
D.K
But I was sure it didn't. Maybe that's for images only. I was sure I remembered someone posting pics a Winston unantialiased.
DK
Post by DK »
Here's a screenshot....it looks antialized to me. I have antializing set to none though.
D.K
Dodgy
Post by Dodgy »
I'd been looking for something like the F5 preview too. This should be in the menus, so you know it's at least available, even if you press f5 all the time :)
Greysnarthur
Antialiasing
Post by Greysnarthur »
Whilst trying the F5 preview, I hit command-F5 and got the voice over!
What is the thinking behind that? Can anyone say?
Lost Marble
Re: Antialiasing
Post by Lost Marble »
Greysnarthur wrote:Whilst trying the F5 preview, I hit command-F5 and got the voice over!
That's a MacOS thing, not an Anime Studio thing - you'd have to ask Apple.
Just to clear something up: the settings you get with Export Animation, like antialiaing on/off, shape effects on/off, layer effects on/off, etc. all apply to just the animation you are about to export. They have no effect on the File->Render command - that command always runs with the default settings. However, maybe there should in fact be a tie-in between the two.
