Uploading Videos to youtube in good quality...
I'm having a bit of trouble uploading videos to youtube- I'm aware that youtube -recompresses your video- which would explain why my animation looks alot better in quicktime than it does on youtube...
However I've been playing around with the options and still cannot get a decent quality- and I also notice that when the camera moves in the video becomes fuzzy...
Is this normal?
Does anyone have any specific combination of settings they can suggest using?
Is this normal?
- Nolan Scott
Well, I would recommend creating your project in 1280 x 720, or higher.
25 or 30 frames per second that’s up to you, but stay with the same frame-rate
and resolution through your whole project. (personally I use 25 fps)
Export as QuickTime:
Resolution 1280 x 720 / Deinterlace
Compression H.264
Quality High / Multi-pass
Data-rate Automatic or at least 3000 kbits/sec
Sound AAC, Mono, 44.100 kHz, 64 kbps
Upload that movie to Youtube:
The initial display of your video will be still in normal quality, but now you have the option to click on the “watch in HD” button...
Example:
http://ca.youtube.com/watch?v=0OmXsELT8 ... re=channel
Cheers
Nolan
Compression H.264
Example:
Cheers
Nolan
To be honest Nolan when i clikced on the link I couldn't find the "View in HD option" and your video looks every blurryer than mine! And I was completly dishearten...
BUT- then I found the little button/option and your animation looks truly gorgeous!
I'm gonna try uploading my little test and see how it goes- thankyou for giving me hope!!!
OH YEAH! I JUST DID IT!!!
http://uk.youtube.com/watch?v=Mv8r0qZsxLc
Ok- what i did was-
I used 1290 X 720 (instead of 1280) as youtube prefers this for a HD video...
Also exported into a quicktime animation and instead of selecting H.264 I just used MPEG-4 Video and then- 25 FPS and 3000 KBytes/sec and quality high.
Ok- what i did was-
