load screen
- tiannaidan
load screen
I have looked through the manual on this and can't find anything on it.When I start AS the male character always loads when the program opens.Is there a way to set it so that a new blank screen will load instead of having to close the male character out everytime or even better to have it open with no files.That way I can open the project I want without having to close another one first.
Is there a "Startup" folder in your installation directory? Open it and you'll see the StartupFile.anme. Rename it and you'll get an empty new one when start up. To open your favorite template just rename it to that file and it will start up with the template.
BEWARE! doing that the time cursor will go to frame 1 and you'll have problems adding objects there.
That Winsor sample file is the most annoying and useless thing that Anime Studio has!
- tiannaidan
start up
So I guess it's better to just continue doing the close and open process like I've been doing? Thanks
Re: start up
Just rename StarupFile.anme and don't replace it with your own template unless you know the drawback. It would create an empty file and the time cursor will be at frame 0.tiannaidan wrote:So I guess it's better to just continue doing the close and open process like I've been doing? Thanks
