hi all. i tried this and i found it nice i need your opinion views
i drew arm and forarm in tow separated layers and then rig by 2 bone
but i did few points control
rotate forearm from inside to outside in front of arm
hany rabi3
hany rabi3
hany rabi3
hany rabi3
Vern does this technique all the time -- for "my opinion" I think it's okay but something I really don't find all that useful (I work in 3/4 and moving the downstage arm I simply rotate around down and back up and as quick as it comes it's not noticeable. For upstage arm I dupe layers and move forearm forward, which is a similar technique to this, but since it results in the forearm passing in front of the body I don't need to be very precise about it).
I'm pretty sure Vern's technique for this is well documented here (you could do a search if you want). It's even possible it was that technique that you found elsewhere.
hany rabi3
