hi, all
i was trying to discover a way to create the effect of text dissolving away into whisps of smoke.
itd be a cool effect if i can get it to work right. so far my feeble experiments have proved unsuccessful.
any suggestions would be greatly appreciated!
-Render <-_->
Text disolve into smoke?
- Nolan Scott
Well, you might have to fake a little...
Use a text-layer and keyframe the visibility...
Use particles for the smoke....
(here one has to experiment with the intensity)
If you like, here is a very simple example:
http://files.me.com/nolan.scott/15uigq.mov
Regards
Nolan
Regards
Nolan
Masking and particles would be my suggestion. Have a look at this.
Just replace the grumpy nurse with your text. Adjust background, particle size, transparency, etc. I originally had this as a pixelation dissolve and have here just set the particles with variable blur and transparency.
http://www.BuddhaMind.info/as/bits/dissolve.anme
