Homer Simpson - Lip Synch
GCharb
Post by GCharb »
Hello all
Still on the path to learn animation in ASP and what best character then Homer Simpson to practice lip syncing, so here is my first test.
Homer.mov 555 kb
G
LeeHasPencil
Post by LeeHasPencil »
I'm still new myself, so can't give you expert feedback but from an untrained (viewers) eye. It looked quite good. Although the head turn looked a bit off, like it was from an earlier Simpsons episode.
GCharb
Post by GCharb »
LeHasPencil wrote:like it was from an earlier Simpsons episode
Yeah, actually it is very basic animation from only one drawing. I used only layer animation with a tiny bit of point motion on the brow.
It would be smoother with a front view of he character.
Took around 10 minutes to animate, still not too bad for a quickie.
Thanks for your input, I might make a front vue, will see! :)
G
aleXean
Post by aleXean »
You need more mouth layers, because the sync to me doesn't quite match up.
GCharb
Post by GCharb »
aleXean wrote:You need more mouth layers, because the sync to me doesn't quite match up.
Yeah, only 4 or 5 phonemes at the time.
Working on the story for my project this weekend, might work more on it Monday. Thanks for your input!
G
patricia3d
Post by patricia3d »
I have downloaded. It has nice expressions.
One thing I want to ask you that th mouth is looking like real sympson's mouth. Its looking great.
GCharb
Post by GCharb »
Thanks kkrawal
Like I said, my first real lip sync in AS Pro, and like I said it has only a few phonemes.
I wanted to see how well I could do with a very basic setup, 5 phonemes and one drawing and it turned out okay, AS Pro rocks!!! :)
Thanks again mate!
G
LeeHasPencil
I was under the impression you were some sort of ASP whizz! :D
GCharb
Post by GCharb »
LeeHasPencil wrote:I was under the impression you were some sort of ASP whizz!
Na, I am an enthusiast newbie at AS Pro.
Planning a commercial project with it, discarded Toonboom Animate in favor of AS Pro.
G
jose1984alberto
Post by jose1984alberto »
didi you use papagayo? or just switched the switch manually?
GCharb
Post by GCharb »
jose1984alberto wrote:didi you use papagayo? or just switched the switch manually?
Manually and rather quickly.
G
hitmanimation
brill work
Post by hitmanimation »
fantastic homer simpson really thought it was a work of a genius really well done im also learning the program and that was real good well done you should be proud of yourself as animating is a very rewarding job and youve worked hard on the character and the mouth switches i thought were just like the simpsons keep em coming bud
GCharb
Post by GCharb »
hitmanimation wrote:fantastic homer simpson really thought it was a work of a genius really well done im also learning the program and that was real good well done you should be proud of yourself as animating is a very rewarding job and youve worked hard on the character and the mouth switches i thought were just like the simpsons keep em coming bud
Heheh, that quite a few words there, thanks!
Was actually real easy, made this after a post from someonelse and the whole thing took an hour or two. AS Pro makes those real easy!
Here is the anme file with soundtrack if you want to have a look, ASP 6.1 format.
Homer.zip 486 kb
G
