These are the steps I've gone through to create a character with bones:
1. Create skeleton layer.
2. Create several vector layers inside skeleton layer, each one containing part of the character (right arm, left arm, neck, head, etc.)
3. Use the Translate Points tool to move all objects away from each other in preparation for bone-adding.
4. Add bones to separate body parts, inside bone layer.
5. Use Offset Bones tool to move bones back into position. The body parts follow.
6. Test bones with Manipulate Bones tool. All good.
7. Add two new switch layers (Eyes, Mouth) inside skeleton layer.
8. In the switch layers, draw eyes and mouth in correct position related to the OFFSET head layer. The head, when offset, is above the neck.
When I preview the figure or active the Manipulate Bones tool, all the body parts move to their correct positions EXCEPT the eyes and mouth, which remain at the same vertical position but ALSO jump to the right.
If I translate the points for the eyes and mouth layer -- to try to manually offset them so they'll go in the right spot -- they continue to jump to exactly the same spot.
The first time I tried offsetting bones, and then tried to make modifications to my work, I had points twisting all over the place. This is my second attempt.
Is there something wrong with my workflow? Is this a known bug? Is there any way I can salvage my character, or must she remain strangely eyeless?
If anybody's willing to take a look, the project is here (and the layer is the "Lady Thumpton Skeleton"). Please don't be cruel: this is still a rough version and I am not a visual artist.
http://dangermuff.com/Boat%2001c.anme
Cheers,
Muffy.
[/list]
