Can I change layers during the animation?
robymcfarlane
in a character, even those behind the program, there are "switch layer" for each position of the limbs, "open hand" "closed hand ".. if I want to change layer, for example at the frame 72, why it also changes between frames? .. please can anyone explain me how can i do?
This explained in the tutorials. They are listed in "Help | Help...".
What does this mean?:
And what does this mean?:robymcfarlane wrote:...even those behind the program...
Anyway, if you right-click on the Switch Layer, you will get a list of the different layers it contains. Click on one to select it.robymcfarlane wrote:...why it also changes between frames?...
robymcfarlane
sorry for may bad english.. i mean: into anime studio there are some character.. like the girl at the start.. if i want move her hand open to closed, there are 2 different layer in the switch layer.. changing layer change all the frame... then if i want an hand open at frame 0 to frame 71 and closed it at frame 72 i can't do it.. because my hand become closed also in the previuos layer... I do not know if I can make myself understood.. i tried this in the tutorial or in the manual, but I found nothing ..
The program cannot read your mind. On frame 1, right click on the Switch Layer and set hand to 'Open'. Then go to frame 72, right click on the Switch Layer and set hand to 'Closed'.robymcfarlane wrote:...then if i want an hand open at frame 0 to frame 71 and closed it at frame 72 i can't do it.. because my hand become closed also in the previuos layer...
robymcfarlane
