PSD export don't work
Imago
Post by Imago »
Someone else tried to export in PSD format?
It exports only white empty frames...
PARKER
Post by PARKER »
I have just tried, i had not problem.
Imago
Post by Imago »
What options you used?
ponysmasher
Post by ponysmasher »
One thing I've noticed is if a layers visibility is animated it won't show up when opened as a sequence in After Effects. If I need to animate the visibility of a layer I just put that layer into a group layer that stays visible.
Other than that I have had no problems with the photoshop export.
The settings I use are the first three checkboxes ticked (Antialiased edges, Apply shape effects, Apply layer effects)
PARKER
Post by PARKER »
Imago wrote:What options you used?
I only exported one frame with the default options checked.
Imago
Post by Imago »
ARGH! :shock:
Now it works!
I've retried without change the options and it worked...
I used the first three options plus the "extra smooth" and the image are perfect.
How strange...
