First pass at dog animation
This is a first pass and needs a lot more work yet but thought I'd post it. The dog is meant to be running away scared and slipping a bit as he goes. The final version will have the camera a lot closer following the dog.
http://www.youtube.com/watch?v=pLtnprAD-IA
- fracturedray
Reminds me a lot of watching my dog run on the linoleum floor.
I look forward to seeing the more polished animation but I think what you have is a great start. Wanted to ask if you plan to make him slide a bit more when he changes direction? I think it would help to give him a little "moon walk" slide before he faces away from the camera.
Hi animation world.
I may do. That's the part of the animation that I'm least satisfied with at the moment so I will see where it takes meWanted to ask if you plan to make him slide a bit more when he changes direction? I think it would help to give him a little "moon walk" slide before he faces away from the camera.
There's a close up shot of the dogs face before this one showing his fear so I think it will be clear why he is running off. I will change his expression and, don't forget, the camera will be closer on the final thing.I'm interested to see how you will convey his fear. He's moving around so much that it may be hard to read his facial expression, but on the other hand, it's a great opportunity to animate expressive body movements.
Thanks for the useful comments.
Nice work again, AmigaMan. Thanks for sharing.
Just something to add, last 2 or 3 turns doesn't look too smooth for my taste, maybe you could tweak that a little
But, obviously, maybe it's just me.
- neeters_guy
I really like your character designs. I had the same reaction as selgin though, it seems to pop a bit (although you did say this was a first pass). You could try that trick where you trace the points of the movement (of the head for example) to see if it flows in a smooth arc.
Looking forward to see how you refine this.
I've now had chance to do a second pass at the animation.
http://www.youtube.com/watch?v=6jicFIN_DPg
Blocked in the ears and tail. Scaled bones for squash and stretch and to make the sliding turn near the end of the shot more fluid and convincing.
- neeters_guy
Thanks for the comments.
Animation pass 3.
http://www.youtube.com/watch?v=rF4AZqjhTxU
Adjusted spacing here and there to improve flow of the action. Animated tongue and collar.
Animation pass 3.
