Hello I cant open my file anymore!
And I really need to get it to work!
I upload the file here so u can se the error!
PLZ help!
MUST have it to work!
http://www.2shared.com/file/b9_M7Z6-/Untitled.html
THX!
NEED HELP!
- patricia3d
I tried to open but I get the error
Could not open file.
Error Details:
Read error at line 179035. In code file ..\..\lib_moho\animval.cpp, Line 42
I think Developers can help you. Or some thing new you have done, leaving that use previous verions of the file. I always save my file with different names after some new work is done in the same file.
Error Details:
One of your layers got "squashed' during a save. The file didn't complete the write process and one or more layers got stripped off.
To fix the file open in a plain text editor like notepad.
Do a search for
(This is the name of the broken layer that needs to be removed.)
Select all the text of this layer starting at "layer_type 1" above the name of the layer to the end of the file and delete.
(Select starting from and including the line "layer_type" above the name to end of file and delete)
This removes the broken layer. Now type a "}" so the last 4 lines of the file look like this now:
Save as an .anme file with a new name (just in case) making sure your text editor doesn't add ".txt" to the end of the file name. You want ".anme" at the end of the file name. Sometimes notepad insists on putting .txt at the end.
Open the new file in AS. It should open now. Of course that layer and any layer "below" it in the file is gone because of the corrupted save.
Do a search for
name "overkroppen"Select all the text of this layer starting at "layer_type 1" above the name of the layer to the end of the file and delete.
layer_type 1
### generic layer values
name "overkroppen"
quality_flags 2044
animated_layer_effects false
origin 0 0
(select to the end of the file and delete)
groups 0
}Open the new file in AS. It should open now. Of course that layer and any layer "below" it in the file is gone because of the corrupted save.
