Hi Rudiger, does this mean you have a new version out somewhere?Rudiger wrote: In the newest version you can assign mutliple target morphs per bone, so you can add one layer order morph (eg left ear behind head) to the "left"morph bone and another (eg right ear behind head) to the "right" morph bone. When you're exactly at midway between the "left" and "right" morph bones it switches the layer order over, which is exactly what you want.
Bone morph dials script
I am currently developing a new version, but haven't released it anywhere yet. DarthFurby and funksmaname have put their hands up to become beta testers for it, so I should be able to package something up for them soon. To be honest, I don't think they know what they're in for! I was playing with different workflows a lot, so there's many, many more options than the released version, which is why I've been reluctant to post it to this thread.ulrik wrote:Hi Rudiger, does this mean you have a new version out somewhere?Rudiger wrote: In the newest version you can assign mutliple target morphs per bone, so you can add one layer order morph (eg left ear behind head) to the "left" morph bone and another (eg right ear behind head) to the "right" morph bone. When you're exactly at midway between the "left" and "right" morph bones it switches the layer order over, which is exactly what you want.
That sounds really interesting!Rudiger wrote:I am currently developing a new version, but haven't released it anywhere yet. DarthFurby and funksmaname have put their hands up to become beta testers for it, so I should be able to package something up for them soon. To be honest, I don't think they know what they're in for! I was playing with different workflows a lot, so there's many, many more options than the released version, which is why I've been reluctant to post it to this thread.ulrik wrote:Hi Rudiger, does this mean you have a new version out somewhere?Rudiger wrote: In the newest version you can assign mutliple target morphs per bone, so you can add one layer order morph (eg left ear behind head) to the "left" morph bone and another (eg right ear behind head) to the "right" morph bone. When you're exactly at midway between the "left" and "right" morph bones it switches the layer order over, which is exactly what you want.
I'll keep an eye on this thread. It's a fantastic script you made, thank you!
regards
- funksmaname
I'm not sure that 'reloading' a multiframe action for repetition will be that useful universally... the workflow of going into actions and changing them is so smooth that you can always manually sync the animated action to where it should be... some more mechanical actions might benefit but then you can set them up as cycles anyway.
this script has rekindled my entheusiasm for AS!
- funksmaname
Morning Rudiger!
I have come up with a feature request - hope I can explain it. You may have already thought of it, but just in case here it is:
You mention being able to assign multiple morphs to a single bone? Not sure how youmade this work but my idea is to seperate the number of actions equally around the 360 rotation (or 0-100% of proximity to the control bone)
e.g.
you have the following actions, with the added naming convension below
ShoulderUp:1:roboBoogy
elbowUp:2:roboBoogy
wristUp:3:roboBoogy
fingersUp:4:roboBoogy
now you could create a control bone for any of those, but if you create a bone called 'roboBoogy', it will be split into quarters with each quarter relating to 1,2,3,4 above (and in that order) so just rotating it does the classic breakdancing move (although it's probably not called 'the RoboBoogy' you get the idea)
additionally, you could add the following action;
ShouldDown:2:roboBoogy
so that as you enter segment 2, where before the shoulder would return to its starting position, this time you are specifying that it goes down (past its starting point).
This brings you closer to the 'one bone animation' target
the original thought was that you could assign all phenomes to a single bone, and then use it like a theramin with a static control bone like I showed in my 2nd vid. but you could assign a bunch of unrelated actions to a sequence - heck you could even assing an action to several sequence bones by naming it thus:
ShoulderDown:2:roboBoogy,1:shrug whe're 'Shrug' is it's own morphDial bone!
I don't know if this is possible, or makes any sense, or whether you've already tried it... but thought i'd throw it out there! Could be really useful and minimise control rig clutter...
e.g.
elbowUp:2:roboBoogy
wristUp:3:roboBoogy
I tried again and failed. Could the interpolate bug in AS7 be causing the problem? Does anyone else use this script with AS7?
Any who, take a look and see if I might be doing something wrong.
Thanks,
Stephen
http://www.youtube.com/watch?v=-c_BbgjwFcg
Thanks,
Stephen
- funksmaname
hey sbtamu, did you actually fix the menu dialogue box? you don't show it in your video, and i suspect this is still the problem.
Go to the script menu, and open the morph>set bake morph-dials options
and in there, make sure that the two text boxes at the bottom are not empty.
By default the name to use should be 'MorphDials' and the seperator is ;
I cover this at the start of my 2nd screencast... but this is almost certainly your problem!
hope that helps
hope that helps
Boy I feel stupid, I had the morph dial layer named but not the other one.funksmaname wrote:hey sbtamu, did you actually fix the menu dialogue box? you don't show it in your video, and i suspect this is still the problem.
hope that helps
Thanks a lot, that fixed it.
Good morning to you as well. I'm in Australia, so our timezones are pretty much lined up for a change.funksmaname wrote:Morning Rudiger!
e.g.
elbowUp:2:roboBoogy
wristUp:3:roboBoogy
Yeah, I had already thought about this approach, but to be fair, I have been thinking about this stuff a lot longer than you
I would also like the scale of the bone to affect the strength of the morph. That would let you tweak transitions from morph to morph as well as transitioning between morphs that aren't adjacent to each other in terms of the rotation angle. The only issue is that controlling the scale and rotation of a bone is cumbersome and doesn't always interpolate well. However, I have another script, similar to Heyvern's AimBone script, that lets you simultaneously control the angle and scale of a bone by making it's tip stick to another bone.
That would let you set up rigs very quickly without having to make lots of adjustments to the placement of each action's morph bone, while still having similar control. I agree it's perfect for phonemes, but with the bone scale controlling morph strength, it's also perfect for head rotation.
Also, how cool would it be to have one of these multi-morph dials for shape/layer order! You could do some amazing pseudo-3D animations with that level of control.
- funksmaname
Hey, that's cool!
Yeah i realise this thread is a year old (still kicking myself)
I wanted to try something a little more practical, which included lipsync... I created phenome actions on the face vector, as well as phenome actions to trigger them on the MotionDials layer - then used papagayo to create a .dat file which I applied to the MotionDial bones using Remon's 'Lipsync with actions' script.
I think the 'mood dial' mixture worked quite well with the generic phenomes which were seperate - this will really give a lot of options when animating.
Also, i used the blink bone to blink by rotation, but also used it for subtle eye movement by animating the control bone (blue) next to it.
This is the only workflow i could get to work for the lipsync - i'm still a little rusty on baking and creating new morph positions - doing the lipsync any other way (actions using rotation rather than movement) just caused odd behaviour. I couldn't have the lipsync on the face layer itself as it was overridden by the motiondials... however this seems to work ok
The head rotation uses a normal bone on the bone layer which is holding everything inside it - however i tried rigging the pupils to a bone too and no matter what i did (even after baking) they just wouldn't move... i'm sure i can work it out eventually
http://www.youtube.com/watch?v=8NInaZz1ASM
That's very impressive, Funk! You might be a year late, but you're certainly making up for lost time now!
I'm curious though, why did you do the phonemes by moving the target bones? Surely for this case where you only want one morph active at a time, it would make more sense to move the control bone around. Then you would only have one channel of one bone to worry about.
- funksmaname
yeah, that's the first way i did it, but it didnt really work - the control bone was swooshing all over the radius mid phenome so the blending wasn't on... The lipsync didn't seem snappy this way for some reason, and some phenomes seemed to be lost completely... it may have been due to the speed of the control bone and had i baked it maybe the results would have been the same??
i also tried just tilting each bone 45degs, but for some reaosn when importing the dat with Ramons script i got a large group of them all turning at once cause silly results
its not too difficult though, all i had to do was for each phenome action i moved the relevant phenome to the center point - 1 frame - and the .dat file took care of the rest...
I'm pretty sure the tool buttons arent working at all for me, they dont appear to do anything! i've not managed to tweak or save targets other than going into the action and editting...
I see what you mean. At least with the control bone being fixed at the centre, the target bones always have to be moved the same distance for each transition, which would be good for consistency. It would be interesting to see if the transition from phoneme to phoneme looked any better after baking, so hope you can get that working soon.
- funksmaname
