Bone morph dials script
Render error in AnimeStudio7 but works in AnimesStudio 6
I tried this script in Anime Studio 7 but Not render in Anime Studio 7.
Then I tried to render in Anime Studio 6 and It works fine.
Re: Render error in AnimeStudio7 but works in AnimesStudio 6
Could it be that it works to render in v.6 but not in v.7, cause my version 7 always crash when rendering?kefen109 wrote:I tried this script in Anime Studio 7 but Not render in Anime Studio 7.
How about you funksmaname, have you tried the script in version 7?
This is with AS7 pro and It renders just fine with Morphdials and never crashes. Windows XP, 32 bitsbtamu wrote:This is my 1st try at using MorphDials. I just tossed a mouth on AS prop hair and eyes and only used 4 phoneme.
http://www.youtube.com/watch?v=mZ0BztguZdw
I'm glad I finally got it to work!
Thanks for the help!
Stephen
hmm..ok, well for me (on mac) it never works, the lua consol pops up and AS crashes, unfortunately the lua consol freeze and is unable to write a report.sbtamu wrote:This is with AS7 pro and It renders just fine with Morphdials and never crashes. Windows XP, 32 bitsbtamu wrote:This is my 1st try at using MorphDials. I just tossed a mouth on AS prop hair and eyes and only used 4 phoneme.
Stephen
It crashes for me also (AS7 + W7 64-bit). The fact that AS6 worked fine for everybody points to a bug in AS7. Very interesting that it seems to work on XP, though.
I'm going to try and boil it down to the simplest case possible that still causes a crash and report it to Mike. Hopefully, I'll get it done before 7.1 gets released.
In the meantime, you could try removing the embedded scripts and using the bake method instead.
Yes that would be great, thanks!Rudiger wrote:It crashes for me also (AS7 + W7 64-bit). The fact that AS6 worked fine for everybody points to a bug in AS7. Very interesting that it seems to work on XP, though.
- funksmaname
- funksmaname
Works on AS7 Pro, Windows XP 32 bit, rendered as AVI uncompressed.
http://www.youtube.com/watch?v=2uXlUxLhvwA
- funksmaname
Sure no problem.funksmaname wrote:I'm on vista 32bit, AS7, exporting insta-crashes regardless of codec... i dont think it's a codec issue tbh... Stephen can you post your file? i will try and render it this end.
Do you ahve any other scripts installed?
D.
ATM I have Two Way Ticket, Adjust colors, and MorphDials no others scripts on the PC.
here is file...
http://www.sendspace.com/file/zb5c5m
Stephen
- funksmaname
