Masking problem with example
7Powah
I've Clicked and Clicked
Post by 7Powah »
I'm sorry but this has been kick my rectal region all over the place. :cry:
The effect I wanted to create was to have a woman's dress move around. Say if she was dancing, but the pattern being underneath and the dress being able to go anywhere on the screen. Did I make sense :?:
I just can't seem to get this :!: :x
Can someone idiot proof it for me as to what steps I would do PLS :!:
"I couldn't help but notice your pain. Share it with me!!!" Share the knowledge so we all may grow stronger from it.
OK, you will need
- a dress layer as the mask
- maybe a second dress layer as the outline for the dress
- a layer with the pattern.
All these have to be in the same group or bone layer. It is a good idea to have a separate group just four this purpose. The setup is somehow like this:
bone layer
> dress layer as outline
> pattern layer
> dress layer as mask
The pattern layer needs to be layer bound to an extra root bone in the bone layer, otherwise it would move with the dress. I do the dress layer mask animation first, then duplicate that layer and set its fill to zero opacity to get the outline only.
Now the masking settings for each layer should be like this:
bone layer: hide all
> dress layer as outline: don't mask this layer
> pattern layer: mask this layer
> dress layer as mask: add to mask, but keep invisible
http://www.slowtiger.de/examples/dresstest.anme
http://www.slowtiger.de/examples/dresstest.mov
Ah, on second reading your post I noticed I've misunderstood a bit. You don't want the pattern to stand still but move on its own independently from the dress? No problem at all.
Just do 2 sets of bones in the bone layer, each of it starting with its own root bone. One would be for the dress, the other for the pattern then.
7Powah
Post by 7Powah »
@ slowtiger: no you're exactly right about what I was trying to accomplish in your first example. However after looking at your second example. My question would be, "would it come out like the first exam. looks, but with me being able to still move them independently?
You could try that yourself, that's why I added the .anme file. Just move the bone in the upper right cormer which is the one the pattern layer is bound to, or add some more bones to it and use flexible binding.
I just did this in the same file: selected that upper bone and translated it while the dress movement remained he same. As you see those two layers can be moved totally independent from each other.
http://www.slowtiger.de/examples/dresstest2.mov
7Powah
Post by 7Powah »
@slowtiger: :D Thanks a bunch for the assistance. You solved my problem on both counts. My hats off to yah!
realsnake
Post by realsnake »
i wish anime studio had something similar to adobe clipping mask effect but the current masking tech. makes my head spinning while trying to achieve some result.
7Powah
Post by 7Powah »
@realsnake: I suggest if you haven't done it already. Use slowtiger's example and file above and maybe that'll help you get the hang of it.
