I am not talking about animation being a lot of work, I am talking about jahnocli and his method of bringing Expression drawings into Moho.Rasheed wrote:Animation is always a lot of work, so what is your point? If I seem blunt here: it was non-intentional.I just find it lots of work & the files still have lots of points - so obviously I must be doing something wrong.
The point is, if you do how jahnocli says - draw in Expression>Flash>Moho it is lots of work to optimize each curve. Sure, if you have one single black line (as he drew), one can easily optimize the line in Flash, but if you bring in a detailed drawing into Flash from Expression that uses complicated brushes, brushes that overlap, one has to go curve by curve by curve to optimize it. There can be hundreds and hundreds of curves that have to be optimized in Flash.
This is too much work, this is a waste of time.
I am saying that although jahnocli got it to work using a simple line (I still don´t know how many points are in his drawing) it is not worthwhile or possible to use his described technique on a detailed drawing created in Expression.
Such as illustrations like this:
I invite anyone to show me how it is just "click, click" and the number of points are reduced in an Expression drawing from 10,000 or 50,000 to 500 or fewer while still maintaining the drawing´s look. That would be great.
And if one is just going to draw a solid line around a character - why go to another program when you can probably do it in Moho? And do it a lot faster and you don´t have to learn or buy two or more other programs?
