Floating point after releasing it from binding
torncanvas
Post by torncanvas »
I've seen someone talk about how to fix this problem, but I forgot where, and after searching the forums for a half hour I really need to be figuring this out.
I used the Bind Points tool in an attempt to fix a skinning issue, but now I want to put the point back to Region Binding. How do I do this again? I released the point from binding to the one particular bone, but it's just floating there not attached to anything.
I swear this is a known bug with a known solution, but I forgot where I found it here and I hope someone can help point me to it...
http://www.intuitiongames.com
http://blog.intuitiongames.com
torncanvas
Der, not really a bug at all.....it's in the menu. Got it! Man, I never use that menu...
Heh, so yeah just for easier searching for others, the problem I've having is this:
I used the Bind Points tool to bind a point, then I released it later, and it's just floating there not bound to anything.
And the solution is:
Select the points you want to Region Bind again, then go to the Bone menu and choose the second option "Flexi-Bind Points."
