Hello.
I just started using Anime studio so im not really familiar with it.
I have a questions about animation:
1. How do I make it so that at one point an image appears in the center without it moving to the center slowly while the animation is playing? Its outside of the view.
2. Can I make a character fade out?
3.Can I select two layers at the same time?
-thanks
Help (noob questions)
- Víctor Paredes
Re: Help (noob questions)
no, but you can put together into a group layer. it's not the best way, but works.megaboy3 wrote:3.Can I select two layers at the same time?
"Opacity" (actually transparency) display is a setting in the Display Quality options (the menu item at the bottom right of the project window). If Show Transparency is turned off then it won't be displayed. (it is confusing that is called "Opacity" in one place and "Transparency" in another).
Opacity or transparency of image layers doesn't display in preview or edit mode, only vector layers. The only way to see the transparency of an image layer is to render.
