Change Rain Color? Pls, help
bilginey
Post by bilginey »
Hi everybody, is it possible to change rain color, after choose rain effect (scripts>particle effects>rain), you know it is soft blue I want to change it into black, thanks a lot all of you again ... [/b]
Nolan Scott
Post by Nolan Scott »
Open the Particle-Layer / select the first Vector-Layer / zoom in until you see the stroke /
select the Select-Shape-Tool (Q) / in the viewport select the stroke (you’ll see the checkerboard) / hold down the option/alt-key and choose your colour from the Swatches /
do the same with all Vector-Layers (p1 - p6) / close the Particle-Layer / play your animation.
Cheers
Nolan
bilginey
Post by bilginey »
Nolan Scott wrote:Open the Particle-Layer / select the first Vector-Layer / zoom in until you see the stroke /
Cheers
Nolan
thanks a lot sir , :D
