Wierd bug
Hiddicop
Wierd bug
Post by Hiddicop »
This i a curved line with a thingy on one end. All of it is a shape.
Now I add a line between two of the points, and WHOA! what happens?
I must say that I can't see the reason for this, so it's probably a bug. I'm using moho 5.0.8 in Windows 98, if that helps.
Lost Marble
Post by Lost Marble »
Sorry, I can't see your pictures. It tells me "The image cannot be displayed because it contains errors."
Hiddicop
Post by Hiddicop »
That's odd... It works for me. But now I re-uploaded the pictures. Hope it works now.
Agent
Post by Agent »
same prob
Image Image
Lost Marble
Interesting. What you've done is found a roundabout way to create an "illegal" shape. Try this: select the final weird shape and delete it. Now, select all the points and try to create a shape - Moho will only allow you to create an outline, not a fill.
This is because the filled shape is "illegal" - it has undefined boundaries. It seems clear to us what parts should be filled, but to Moho it's not at all clear. So, when you try to fill the shape, Moho just won't let you.
However, by first creating a legal, filled shape, and then modifying it to make it illegal, you found a sort of "loophole" that lets you create invalid shapes.
During beta testing for Moho 5, we tried out a feature where illegal shapes like these would be automatically deleted. However, this seemed really confusing to users. I'm not sure what the best solution is - I gues just "don't do that".
