Cycling deleteable without losing the keyframes?
whitelady
Post by whitelady »
Hi there,
unfortunately the forum search won´t work, therefore:
I´m playing around with cycling, but couldn´t find out yet how to delete a cycling, once I created it – except by deleting the keyframes and having to animate the keyframes anew. Is it possible to delete a cycling and keep the keyframes?
Thank you already for your answer!
Nadine
chucky
right click.
Post by chucky »
Hi just go to the cycle point and right click on the arrow that points backward indicating the cycle, then select one of the other options like smooth.
I normally do cycles as an action, try opening the action window and getting started with that concept, it can be very useful, and you can use a reference of the action or have the action pasted into the timeline as keyframes, it's cool.
