The tutorial say to select the "Script->Sound->Bone Audio Wiggle menu command" to create this effect.
But I can't find that anywhere. Where do I go for "Script"? Is that command in a special or hidden tool bar?
Or do I need Anime PRO for this task?
Obviously I'm a newbie...
Cheesy Talking head effect
But you can get mostly the same effect by simply using a .WAV sound and a switch layer that just contains two shapes -- the open and closed mouth. It's about as basic a talking head as you can get (I'm guessing the wiggle mouth is a little more silly, but you ought to at least see the other effect to see if it's something you want).
