Delete Curvature Keyframe
rodannr
Post by rodannr »
Hello.. This is for sure something too dummy but..
I have some curvature type keyframe in my timeline, but when i press Alt+Backspace to delete such.. then.. they just dont get lost.. that does not happen with other KFrames types..
What am i doing wrong?
You must have created a spline or point on a frame other than 0. Whenever you create new splines or points on frames other than 0 no key is created on 0 and you can't delete that key on the other frame because apparently you would need at least one key.
Select the key you are trying to delete, copy/paste to the frame 0 key and now it should delete from the other frame.
rodannr
Thnks!
Post by rodannr »
That sounds pretty logical.. at the programming point of view that AS was made.. of course.. those keys outside the 0 frame belongs to it in some kind of hierarchy... Thnks..
Ah.. by the way.. you're pretty famous because of your "head turn" technique..
Best Regards :)
Rod.
