From a generous forum member HOSAMALABARY (I think) I've downloaded the following set of brushes:
http://www.darthfurby.com/genete/Other/brushes.zip
They look great!
But unfortunately some of them makes AS 5.6 under linux to crash when select them in the selection dialogue.
Can you test if one of the followings brushes makes your system crash? If so it is a really strange bug.
and many others.
Brushes that makes AS crash
Ok, I know this one drifted up because of spam but I'm going to answer the original post since no one have.
Occasionally I get brushes like this.
Sometimes it works to rename the brush. Otherwise try to copy the brush into a new image and save that.
But I've also come across situations where I've had a brush crashing AS which I've deleted. Then created a completely new brush from scratch and saved that as the same name as the old one (so I won't break styles by removing used brushes) and still have AS crash on selecting that new brush!
So, in all, I don't know what triggers the crash, one would think some small data corruption of the image file, but since it happens to completely new brushes as well this doesn't seem to be the case.
