Motion capture with mouse - is it possible in Anime Pro?
huertaaj
Post by huertaaj »
If I could have ONE THING added to Anime Pro I would request motion capture with the mouse. I used to animate with the mouse using the old Autodesk Animator Pro in DOS and early Windows. Now I NEED to do the same with Anime Studio Pro. Does anyone know of a way to do this in Anime Pro?
TNX,
huertaaj
You can do a funny thing:
New file
Go to frame 1
Select the Freehand tool.
Press the space bar and draw meanwhile the animation is playing.
It would produce an animated outline (default values) that follows your mouse movements.
:D
You can also hit the play button and move layers or bones or points while it plays... not very accurate or controllable but it works in a pinch. Turn off skip frames if you try it.
