problem with shot over 700 frames
Discuss Papagayo issues here
barefootgen
Post by barefootgen »
hi all,
been using the software, its great.
i'm having a problem with a wav file that is just over 700 frames long. it imports but i cant position the words beyound the 700 frames mark
any thoughts? am i being stupid?
thanks
n
mkelley
Post by mkelley »
After you load up the file change the frame rate -- doesn't matter what you change it to -- and then change it back to your desired rate. That should fix this problem.
FloridaJo
Post by FloridaJo »
I have the same problem and I can't change the frame rate.
Mac OS X 10.5 Intel
