problem with obj files?
megaboy3
Post by megaboy3 »
Hello,
I exported a simple 3D studio max object to a obj file
but when I imported it to Anime studio black lines showed up in the
bottom of the screen. And you couldnt move them either.
Is there something I need to do before I import it?
MB
phastraq
Post by phastraq »
There is a free prog called wings 3D. Try importing your file into that and exporting as an obj file again.
You can use that prog to convert almost any 3D format into a suitable obj file for ASP. I have used it a lot with great success.
Also try and keep your objects simple as ASP is not a real 3D prog andd slows down a lot with high poly objects.
