A question about moving layers.
Bones1991
Post by Bones1991 »
hello.
I was just wondering, is it possible to make one layer move under and or above another in a later frame? Example:
for the first 30 frames layer order would be:
1TV
2background
3Alden
then I want to make him come in from the background through a door that u can see him standing which I didn't add color.
1Tv
2Alden
3Background
when I tried doing it, it would move but stay like that from frame 1- whatever. is there anyway I can make it move for just a few layers then switch back to where he is hidden in the background again?
Thanks
Andrew
If you have AS Pro (you don't say) you could put these three layers into a group folder, then you could swap layer order around during the animation -- a new feature introduced in the most recent update.
Bone layers and group layers are identical. If you have standard a bone layer is exactly the same as a group layer... it just can have bones too. I think the group layer is a useless redundant feature.
heyvern wrote:Bone layers and group layers are identical. If you have standard a bone layer is exactly the same as a group layer... it just can have bones too. I think the group layer is a useless redundant feature.
Just trying to keep things simple for a newbie. Try leaving the soapbox at home now and then?
mkelley
Post by mkelley »
Vern wasn't on a soapbox -- since Group layers are only available in AS Pro his point was that even someone with the standard version can use a Bone layer in its stead.
(I *think* that was his point -- but perhaps it's too early in the morning for me to be thinking straight. Is layer ordering only available in AS Pro?)
That was my point mkelly. I guess the last bit was a bit of a soap box.
I find the "differences" between bone layers and group layers to be MORE confusing to those with the standard version. I just like to point out they aren't really missing anything. There is no difference between the two layers and we always have to say "if you have standard just use a bone layer instead of a group layer."
The fact remains that bone layers and group layers are identical in function except that bone layers have bones. That is what makes group layers a bit redundant... maybe not totally useless though. ;)
Yes, both standard and pro have animated layer ordering.
p.s. I slipped off the dang soap box and nearly broke my hip... it's very slippery on a soap box. ;)
chucky
Post by chucky »
I hope you are okay Vern, serves you right though.
I love my group layers, I would get very agitated should they go anywhere.
I was thinking , that what with group layers, switches and root bones, this forum can sound a little bit 70's.
boomshikawahwah. :P
