Rigging the ship (using face turn technique)
GraphicAnime
Post by GraphicAnime »
Hello,
I'm getting used to Anime Studio Pro and it's bone system. I wanted to use a trick that would make the ship look like it's turning. I was trying to use the same boning technique from the Head Turn tutorial from Simthmicro site. Even though I followed the directions, the bone size button remains inactive, even though I set the size constraints.
Here is the actual image: http://s204.photobucket.com/albums/bb31 ... _final.jpg
Here is the screen shot of how I set the bones. What I wanted to do is as the ship turns towards it's right the wing, on the furthers side, slightly disappears. http://s204.photobucket.com/albums/bb31 ... as_pro.jpg :?:
DK
Post by DK »
Hi GraphicAnime....If you are using the scale rotate method from my tutorial I may be able to help you. Can you send me the file to look at?
PM me if you would like.
Cheers
D.K
GraphicAnime
Binding Points to Bone Issues
I'm currently having a problem with binding the points to the points.
Originally I had the points binded to the selected bones. I wanted to reset the binding one bone to the whole layer. Then I selected Flexi- Bind Layer. Now when I try to re- assign the points to the individual bones again, the points do not move with the bones when I animate it.
When I select the bone again I see that the points are assigned, but it appears to be not working when I try to animate it.
Thanks in advance
